May 20, 2018, 09:06:20 AM *
Author Topic: Heater hose route question  (Read 4254 times)
wal1809
« on: April 21, 2010, 03:53:33 PM »
Hello bus folks,  Wayne here.  1984 Silver Eagle Model 10.  I have a question about the heater hise route.  In the rear bay, right side back wall are three sets of hoses.  They are green maybe 1 1/4 inch,  red 1 1/4 inch and red maybe 3/4 or 1 inch.  I am assuming the green is for the air, red is for the heater.  The big red Hose comes from a ball valve at the motor and dissapears into the rear bay wall just inside of where the tag axle is located.  Coming back out is the smaller red hose and into a sheet metal pan that is on the roof of the bays and runs the length of the bays.  I am assuming it feeds hot water to the driver's heater.
If it is the driver's heater my next question is, does it circulate hot water all the time and the driver merely allows air across the heater coil upon demand?  If so I want to tap into that hose above the front bay and route the hose to the waste vegtable oil tank to heat that tank.  It would not do me any good if it is not a constant hot water circulation.
I thank you all for any and all advice.
www.snakebreaker.com
« Reply #1 on: April 21, 2010, 04:23:00 PM »
Wayne, not knowing how someone has plumb yours they are supposed to come from the engine go to the circulation pumps (2 one on each side) then to the 2 control valves at the front fwiw you are not going to have much up front without the pumps.
BTW Happy Birthday see how long you can hang on being 39 lol
wal1809
« Reply #2 on: April 21, 2010, 04:33:55 PM »
I got a chuckle out of that because I told a young girl the other day I was 39 and she couldn't beleive I was so derned old.  I laughed to myself because i was her age just the other day.  The poor girl has no idea how soon she will be in her 40s.
I am not sure I know what you mean on the pumps.  Does the water not flow from the engine's water pump?
« Reply #3 on: April 21, 2010, 05:21:23 PM »
I'm only posting this for your information because we have a model 01. Ours does not have any cirulating pumps, at least not that I have found. The engine does all the work. I'll say this, with the new heater core and assembly I put in the front, it works great. Almost too hot, at least for me. I need to do some more work on it to get it like I want but we never go anywhere in the winter! Wink
Happy Birthday!
wal1809
« Reply #4 on: April 22, 2010, 06:33:56 AM »
How are you dreamscape?  I might need to do the same thing about the new heater core up front.  I do travel in winter.  When I went to Ponca we never could get the bus inside temp above 55 or 65 degrees because the outside temp was 15 degrees with qa 20 mile per hour wind.  All three heat strips could not keep up.
Luvrbus-Where would the pumps be.  It seemes like to me the big 1 1/4 hose fed water to the bus interior heat at one time.  I am guessing the heater coil for interior is or was right behind the right side tag axle, between the tag and the fuel tank.  It is closed off and sealed with foam so I can't get in there.  At least I don't want to get in there if you tell me it is not needed.  Coming back out id a smaller red heter hose and I believe it goes to the front for the driver.  Tapping into that one would be ideal rather than run 70 feet of heater hose to heat the VO tank.  I might buy a 110 volt band heater and be done with it if it is too much of a pain to tap into that water source.
« Reply #5 on: April 22, 2010, 06:50:11 AM »
Wayne, they should be on the back bulk head behind the engine.
Van has 2 on his Eagle you are going to need one the water pump will not keep it warm you'll freeze your a** off in 0 degree weather no matter what core you have up front and adding another loop will make it worse with no pump.
Contact Van maybe he will sell you one of his as one will work for you if you have no luck contact me I have 2 on a 05 at my place here .
« Reply #6 on: April 22, 2010, 06:52:53 AM »
What you need to do is tell everybody that you are 10 to 20 years older than you are.....they are usually surprised at how good you look for your age! Grin
wal1809
« Reply #7 on: April 22, 2010, 07:20:55 AM »
That is the problem I don't look good at all.  I got a sergeant here who everytime I ask "How are you doing sergeant"  His reply is "Old fat and tired".  Unfortunatley I believe I  know what he is talking about.  LOL
Hello Luvrbus.  I believe I know where the pump would be located since your telling me it is on the back wall of the bay behind the engine.  It makes sense the smaller pump on the motor can't push that much water 80 feet to anf from the motor.  It also makes sense down sizing the hose halfway.  I guess if I went to the front and pulled the hose off and started the bus for a second or two I could figure out if the pumps are working.  If they spew water out then I would imagine they are working.  If not then I will get with van or you to get a new pump.
I have figured out that one better like tinkering with this stuff if he is going to own an older conversion.  Otherwise they might not be driving one for long.
SPICEY MEATBALL
« Reply #8 on: April 22, 2010, 08:26:23 AM »
Wayne , Clifford is right, they are located on the rear bulkhead behind the engine above the trans(one each side). Do you still have the ball check valves to shut off coolant flow to the front? I am planning on the removal of the system in the near future, I have not tested the pumps yet, but would imagine that they are functioning as the heater does work.
Ex 1989 Model 15 Predator class War Bird owner
wal1809
« Reply #9 on: April 22, 2010, 09:05:10 AM »
Hey Van,  Yessir the ball valves are still there in the open position.  I am  sure some water is headed up front because the heater does work.  It was just now very efficient because the temp was only 15 outside.  The heat strips on the roof were worthless that is for sure.  I felt like a popsicle when along about Dallas.
Just Dallas
« Reply #10 on: April 22, 2010, 09:17:48 AM »
Removed
« Last Edit: July 15, 2010, 02:25:00 AM by Now Just Dallas » Logged
« Reply #11 on: April 22, 2010, 12:37:10 PM »
Hey Wayne, If it gets cold just head further south! Roll Eyes
wal1809
« Reply #12 on: April 22, 2010, 01:01:06 PM »
Oh we came back south but it wasn't until south of Dallas before we got above 20 degrees.  for a flatland coastal boy it was cold.
SPICEY MEATBALL
« Reply #13 on: April 22, 2010, 02:39:36 PM »
Which coast?
« Reply #14 on: April 22, 2010, 02:55:58 PM »
how about the middle coast Van ,I was watching a game show last week and the young man did not know most of the US is surrounded by 3 bodies of water he could be our next prez what do you think
« Last Edit: April 22, 2010, 03:01:59 PM by luvrbus » Logged
