May 25, 2013, 01:19:58 PM *
Author Topic: coolant flush instructions  (Read 1935 times)
eagle rush
« Reply #15 on: May 12, 2010, 08:14:31 AM »
Hello everyone, quick question, would it be easier to pull the rad. and back flush upside down to get all the junk out?  Also to inspect the rad. or is there not that much junk flaked off inside the rad. for that much work, is it worth it?  I don't know but I also will have to flush the system soon, Thankyou for all the help!!  Richard
« Reply #16 on: May 12, 2010, 12:17:10 PM »
Richard,
Do you have any overheating conditions?  Such as?  How high does it go on a long pull with ambient 90 plus degrees?  What temp does it hold on the level doing 60 or ?  Have you shot the temps on the rad with a hand held no contact temp gun?
I think they need more background,
eagle rush
« Reply #17 on: May 13, 2010, 06:35:49 AM »
Hello John, no the bus has not ran in quite a while but soon, If I remember it did not overheat but it did get hot, above 200? Before I run it again I need to flush the system, change the thermostats and do the best job I can (prevent maint.) to make sure it is done right, to run as smoth as possible!! Thankyou for the questions on what to look for, which I will double check and get back to you, The rad and system needs to be flushed, while its down and drained nows the time.   Thankyou John and everyone for the help, Richard
