May 20, 2013, 06:33:44 AM *
Author Topic: Any one know the part # for the accessory drive pulley thingy that bolts to  (Read 1242 times)
« on: May 17, 2010, 06:08:52 PM »
the back of a 6-71? Do all the other -71 share this part? How about the -92?
Thanks for any and all info. Patrick.
« Reply #1 on: May 17, 2010, 07:39:15 PM »
Pat, are going to drive off the cam or blower
« Reply #2 on: May 17, 2010, 08:20:39 PM »
off the cam. where the generator was.  Will drive a belt for a new alt.
« Reply #3 on: May 17, 2010, 08:34:40 PM »
I'll check tomorrow and see if I have one for you ,how many bolt holes do you have on the bell housing and do you have the drive plate for the cam.
« Reply #4 on: May 17, 2010, 09:23:20 PM »
there are five holes.  My drive plate on the cam is a little chewed from a previous shaft failure  on the genny..it's operational but if you have one lying around.....
« Reply #5 on: May 17, 2010, 10:00:20 PM »
Pat, I don't think that drive is going to work for the accessory pulley the ones I have are a fork type with a coupling between the drive and the accessory drive to protect the gear train in case of failure this is why I don't like the gear driven alternators no protection even the power steering has the coupling and fwiw the 92 series are different they have 6 bolts.
I will check a 71 I have and see what I can come up with
Just Dallas
« Reply #6 on: May 18, 2010, 05:48:01 AM »
Removed
« Last Edit: July 14, 2010, 07:53:01 PM by Now Just Dallas » Logged
muddog16
« Reply #7 on: May 18, 2010, 06:04:57 AM »
Dallas, let me ask a simple question, I've used Powerline's site for cross referencing parts or descriptions, and their site is awesome.  The question is their prices is it me or are they high?........some simple parts (or at least I thought were overpriced or even outlandish) or that was my impression!
I came back to make another comment, using PC's website to verify parts that I've found on ebay to confirm what they actually are and what they fit has been very beneficial too!
« Last Edit: May 18, 2010, 06:16:46 AM by muddog16 » Logged
Pat
1982 Prevost LeMirage
8V92TA/HT754
« Reply #8 on: May 18, 2010, 06:12:58 AM »
Pat,I can help you with the second and third drives for the V's but a no go on the inline 71 give Don Fairchild a call he will have one
Just Dallas
« Reply #9 on: May 18, 2010, 06:14:03 AM »
Removed
« Last Edit: July 14, 2010, 07:52:32 PM by Now Just Dallas » Logged
« Reply #10 on: May 18, 2010, 07:06:48 AM »
Feeling a little thick here.  In the above pics you say the top diagram is for the 6-71.  Is the acc drive the bottom image in the top pic?  It is the only one that looks like it would fit.  ie., 5 bolt holes and a similar looking device for matching to the cam gear.....
I went on the PC site but have not mastered it yet so it was hard to confirm.  If I do work out the site will it be able to give me DD part #s or x referrence #s?
Just Dallas
« Reply #11 on: May 18, 2010, 07:32:21 AM »
Removed
« Last Edit: July 14, 2010, 07:51:01 PM by Now Just Dallas » Logged
