February 20, 2018, 01:32:07 AM *
Author Topic: In need of an Eagle radiator  (Read 7870 times)
« Reply #15 on: May 29, 2010, 07:45:59 PM »
Depends on how they were ordered Van the 330 hp 6v92 was 46ins in both buses  the 270hp 6v92 was 42 inches in both, the 15 with a 8v92 was 48x48x7 like the one in my 05
Oilslick
« Reply #16 on: May 29, 2010, 07:49:07 PM »
What specific measurements do I need to get in order to let Atlas know what I am needing? Thanks!
Kevin
1987 MCI-9- Gone
1989 MCI 102-A2- Gone
1982 Eagle Model 10- Gone
1988 Eagle Model 20 GSA- Grazing
1981 Eagle Model 10 Entertainer- Getting a transplant
« Reply #17 on: May 29, 2010, 07:56:24 PM »
Thanks Cliff, the one my 15 is the temp, 42"er, like to get that bigger 48X48 some day soon Wink but first that 892 Grin.
 Kevin,just get the dimensions of yours first,number of inlets and outlets, atlas has the specs this way they can verify what you have Wink
« Reply #18 on: May 29, 2010, 07:59:49 PM »
Just tell him you have a model M20 1988 model with hydraulic drive and he will send you some drawing to be sure no one has changed it, go ahead and measure the length,width and thickness I am pretty sure Wayne has one in CO.
I'll PM his number to you from the Eagles board.
Oilslick
« Reply #19 on: May 29, 2010, 08:05:06 PM »
I cannot say thanks enough! Thanks so much!
1987 MCI-9- Gone
ArtGill
« Reply #20 on: May 30, 2010, 06:19:20 AM »
About six years ago I replaced my core with one from ABC bus in Fla.  They had purchased all the spare parts that NJT had for the model 20's.  My coach is a NJT 20, 1989 model, but the bolt pattern that connect the tanks to the core was different and I had to have it re drilled.  So, if you get a core only, watch out for that.  If yours is a swing out radiator, rebuild the swivel for the water.  I did my with high temp o rings from the hardware store.
Art
Art & Cheryll Gill
Morehead City, NC
« Reply #21 on: May 30, 2010, 08:10:09 AM »
Atlas radiator in Santa Fe Springs, Ca did my radiator on my bus, rebuilt the radiator on my truck, and is modifying the radiator for the generator on my truck (having them lower the return hose on the cross flow radiator to clear the truck frame).  They do excellent work, albeit it is expensive when dealing with big, heavy, copper/brass radiators.  Mine in the bus is a 6 row serpentine fin.  Good Luck, TomC
wal1809
« Reply #22 on: May 30, 2010, 08:27:55 AM »
I just read the whole thread for I am in need if radiator work.  Recently I have noticed the temp climbing very easily.  I am trying ti decide if it is simply the ambient temp here is daily at about 95 degrees.  I bought the bus in October and it has always run at 180.  At idle about 170 or 175.
Here is what I am trying to decide.  On one if the heat exchangers I had to place it next to the exhaust pipe.  It runs parrallel to the exhaust pipe.  My thinking was "it will help with the heat needed for the oil".  So I am trying to figure out is it the water through the heat exchanger getting super heated from the exhaust, is it because this is the first time I have driven the bus in the Texas heat or do I need radiator service.
I have resolved the issue by telling myself to get the radiator serviced because it can't hurt.  For all I know it has never been serviced.  I keep reading in the threads prior about the different radiator shops working specifically on eagle radiators.  Can't I go to a local guy and have him boil this one out and clean it up? If it is too far gone can't they solder in new fins and be done with it?  Please inform the uninformed me.  Thank you.
www.snakebreaker.com
Oilslick
« Reply #23 on: May 31, 2010, 11:29:34 AM »
Heading out for Nashville in the morning to get the measurements for my radiator. Hopefully I can get a core at a decent price...............what am I saying? It's a bus! Is there such a thing as a decent price? LOL!
1987 MCI-9- Gone
wal1809
« Reply #24 on: May 31, 2010, 12:07:50 PM »
Maybe I should shorten my questions and break them into different sections.
Do I have to find an eagle specific radiator shop or cam any shop service my radiator?
« Reply #25 on: May 31, 2010, 01:18:50 PM »
Wayne, the very best in Houston for radiator repairs is Daniel 3515 E Freeway 713-223-2311 they have been there for years and have provided me with good service and prices over the years.
The Wayside Radiator shop is not bad either forgot the address but it not far from the old Princess Drive Inn on Wayside Dr
« Last Edit: May 31, 2010, 01:27:58 PM by luvrbus » Logged
Just Dallas
« Reply #26 on: May 31, 2010, 02:29:30 PM »
Removed
« Last Edit: July 14, 2010, 07:16:14 PM by Now Just Dallas » Logged
