May 20, 2013, 12:40:26 PM *
Author Topic: Would you call this a sports car?  (Read 1097 times)
« on: May 31, 2010, 06:47:39 PM »
http://palmsprings.craigslist.org/rvs/1723421358.html
Barn Owl
Roanoke, VA
PD4106-1063 "Wheezy Bus"
« Reply #1 on: May 31, 2010, 09:53:01 PM »
I don't think a V730 could handle 450hp. What's the spec?
« Reply #2 on: May 31, 2010, 10:45:32 PM »
Checking online, it seems to be that the 730 is rated for less than 300hp.  Although it is not uncommon for someone selling a bus not really to know what they have, this guy has two buses for sale.  The other one is a 66' MC5a with a Spicer.  It would seem he should know the difference between an 8V71N and an 8V92T.  Is there anyway to up the hp rating on an Allison?
Anyway, I just thought that that kind of horsepower on that light a bus would be quite a performance package.
« Reply #3 on: June 01, 2010, 07:01:09 AM »
The V730 has a low horsepower rating because the main usage of the V730 was for transit buses.  Since the main transmission is basically a HT740 without 1st gear, it can handle the horsepower.  But-the weak spot of any V730 is the angle input gears and especially the quill shaft-a remarkably small splined shaft that connects the engine torque to the transmission.  Good Luck, TomC
« Reply #4 on: June 01, 2010, 07:56:34 AM »
Lots of people install things that maybe shouldn't go together, and live happily ever after...  I think that there are two sides to the torque limits (usually a trans is torque limited, not HP limited) and that relates to the resistance from the weight of the vehicle.  You might get away with over-torquing a transmission that is in a quite light vehicle, compared to a vehicle at 80K gross weight.  And you always have your right foot as a torque limiting device...  If you own it, and know that flooring the throttle on starts may cost you a lot of money, you might not do that so often...
I bet there's lots of people with 8V92's and fire-truck spec 8V71T's with Allison 640's behind them that have been happy for years...
1980 MCI MC-5C converted
Vintage race cars -
1978 Lola T440 Formula Ford
1972 NTM MK-4 B/SR
« Reply #5 on: June 01, 2010, 08:35:08 AM »
The sad thing is that that engine in a vehicle that light should have a couple of overdrive gears to give it terrific milage.
Iceni John
« Reply #6 on: June 01, 2010, 12:18:15 PM »
If it actually has a 92 in it, let's hope he seriously upgraded the cooling system, especially as he is in Palm Springs!
