February 24, 2018, 06:07:56 AM *
Author Topic: What size jack?  (Read 4024 times)
Jriddle
« Reply #15 on: June 17, 2010, 05:45:40 AM »
Here is some pictures of my manual.
John Riddle
Wells NV
1984 MC9
« Reply #16 on: June 17, 2010, 06:33:56 AM »
You also want a pad to put under the jack.  I have a couple of one foot squares of 3/4" plywood.  You definitely need it on dirt or gravel, and even on blacktop on a hot Florida day.
« Reply #17 on: June 17, 2010, 07:06:33 AM »
 I use a couple of 1'x2' x1/2" steel plates for under my jacks.
NEWELL in South Carolina
« Reply #18 on: June 17, 2010, 07:07:30 AM »
I've blown out the seals on a 10 ton jack while jacking up the rear axle of a school bus to swap tires with my dump truck.
That is why I like the 20 ton jack - less stress on the seals for the same weight.
The air over hydraulic is a very nice work saver - IF you have compressed air available.  Cool
it_mike
« Reply #19 on: June 17, 2010, 07:29:53 AM »
That's what I was worried about.  I'll go with the 20T (on sale at Northern Tool...yeah!)
One of these days, someone will have to show me how to tie into the air system.
1980 TMC Crusader II
« Reply #20 on: June 17, 2010, 07:54:08 AM »
It's a bus - it always has or needs compressed air!   Cheesy
I carry a generator and a compressor anyway, in  case I feel the need for a stealthy getaway I can air up the bus without running the engine.  I put quick connects and ball valves in two places - one on the ping tank where I put air into the system through the air dryer (always stop the bus on a compressor charge cycle so the purge valve is closed) and one on the accessory tank drain for taking air out of the bus system.
« Reply #21 on: June 17, 2010, 09:48:02 AM »
I don't know so much about the always has part, but I can confirm the always needs . . .  Grin
When I have compressed air, I don't notice wether or not I need it - it is when I don't have it is when I seem to really need it the most . . .  Grin  Grin  Grin
One of my air over hyd jacks is either-or & can be used manually. The other one is air only - useless without air.  They use copious amounts of air too.
