January 21, 2018, 04:42:47 PM *
Author Topic: ceiling help  (Read 1366 times)
txjeff
« on: June 17, 2010, 09:36:51 AM »
The PO installed the stretched vinyl in the ceiling of the bus. Over time the material has started to sag and is extremely dirty. Has anyone tried to clean and restretch this type of ceiling or would it be easier to replace it with something else? One thought was to glue it with the contact adhesive for car headliners....any thoughts, suggestions, experiences ??
73 MC-7combo
Brenham, Texas
« Reply #1 on: June 17, 2010, 09:44:47 AM »
easy clean,do mine all of time....can tighten or one possibility to create a new look would be to use vinyl covered buttons to give a tufting look..I did on a 12 inch grid..use snaps with screws thru ceiling material to backing..then covered buttons just snap over to cover snaps up....Bob
loosenut
Confidently Ignorant
« Reply #2 on: June 17, 2010, 10:26:06 AM »
I pulled mine down until I could put new adhesive on it then stuck it back up.  It was a pain in the neck getting it back up.  It has held for 6 months.
Mike
Sold 85 Neoplan 33ft 6V92ta, sadly busless
boogiethecat
« Reply #3 on: June 17, 2010, 11:15:22 AM »
For what it's worth I've tried quite a few headliner adhesives and never got much to stick for very long.  Instead of using screws I ended up using a lot of 1/2" diameter by 3/8" thick supermagnets!  They look like buttons, give a nice quilted look and stick everything  to the roof just perfectly!  And over the kitchen I can stick all the knives and forks to them... (why you ask?... why not!)
1962 Crown
San Diego, Ca
bottomacher
« Reply #4 on: June 18, 2010, 05:27:07 AM »
Most buses I've seen have aluminum headliners. Where do you put the magnets?
txjeff
« Reply #5 on: June 18, 2010, 05:39:57 AM »
I had the same question, I ended up pulling the vinyl out last night thinking of replacing it with some kind of wood. Im gonna take this opportunity seal a few leaks and add some insulation.
73 MC-7combo
Brenham, Texas
« Reply #6 on: June 18, 2010, 05:59:59 AM »
I think some of the Crown buses have steel roof panels.  Jack
