May 23, 2018, 04:12:22 AM *
Author Topic: Using Tin tiles for ceiling  (Read 1544 times)
Ed Brenner
« on: June 18, 2010, 05:58:03 PM »
Okay , time to replace the ceiling. It is now foam backed carpet type material about 15 years old. the foam backing has gone bad ceiling letting loose.
It was on my list of things to re-do, just not this soon. It already has a good backing behind it,plywood.Has anyone used the 2' by 2' powdered coated tin tiles that are nailed in place. A zillion different patterns and colors available,little pricey. Will they take a bend at all ? Other chose would be wood of some sort similar to flooring not big sheets. No vinyl , carpet. Any Ideas
Thanks , Ed Grin
Ed Brenner
77 Eagle 05  Murrells inlet, SC
 " While We're At It " A Busnut's most costly Phrase !!
« Reply #1 on: June 18, 2010, 06:03:02 PM »
They also have plastic lookalikes that come in sheets.
« Reply #2 on: June 18, 2010, 06:11:38 PM »
Ed, Jim Smith used the tin in his Eagle I think he bought from Amercian, there is some photos of his on the Eagles board if not I have some pretty sharp trim with  walnut and LED lights.
« Last Edit: June 18, 2010, 06:13:47 PM by luvrbus » Logged
« Reply #3 on: June 18, 2010, 06:38:42 PM »
We used a lookalike material we  bought at Home Depot in the kitchen and a similar pattern in the bedroom. Both syles are flexible, kitchen tiles not as much as the rolled type we used on the curve of the ceiling.
If you look above our oak window frame you can see it, we chose a brushed nickel. Comes 24" wide and 25' long. This came from http://www.talissadecor.com/ Order took 10 days from India of all places. We're not finished installing trim, always a work in progress! Wink
In the lounge we used a brushed antique nickel.
In the kitchen we used the HD product, glues up like paneling, 18" x 24".
We like the fact they are really easy to keep clean.
For more ideas Google faux tin kitchen backsplash.
« Last Edit: June 18, 2010, 06:42:02 PM by Dreamscape » Logged
jackhartjr
« Reply #4 on: June 18, 2010, 06:55:59 PM »
Florida Cliff should chime in, he did it in his Buffalo, looks GREAT!
I saw some on the plastic panels on sale at Lowes for $4.00 each today.
Jack Hart, CDS
8V71 Detroit
4 speed Spicer Trannsmission
grantgoold
« Reply #5 on: June 18, 2010, 11:01:20 PM »
finished mine about 60 days ago. Took some extra work but end result was nice! Layout time was most intense. You will need to find a 30 inch paper cutter on ebay or craigslist. Easy to manipulate and flexed nicely to the original curve of my 9. I have also just finished two rooms for a neighbor who liked the bus so much! I chose zinc self tapping screws and some sealant. As you can see, I also needed to cover the tin as it was raw!
Good luck!
Grant
Grant Goold
1984 MCI 9
Way in Over My Head!
Citrus Heights, California
grantgoold
« Reply #6 on: June 18, 2010, 11:05:32 PM »
some more
« Last Edit: June 19, 2010, 06:13:57 AM by grantgoold » Logged
Grant Goold
1984 MCI 9
