June 21, 2018, 09:32:13 AM *
Author Topic: Lead sheets  (Read 6265 times)
chuckd
« on: July 01, 2010, 09:16:03 AM »
I innocently went into my home building supply outlet and asked if they had any lead sheets for sound insulation.  You would have thought I had asked for first rights to his first born.  "I would not have that stuff in my store", I told him if you did not eat it, or get shot with it you would be okay.  So thought I would come to the source and ask where can I get some lead sheets for sound proofing my engine compartment.  Just went a West Marine store by me and they want 150 dollars for a 32 X 54 piece piece of sound insulation.  That sounded pricey.
So any sources around Minnesota?
Chuck
Brian Diehl
« Reply #1 on: July 01, 2010, 09:20:55 AM »
Chuck, I have a couple of sheets you could have for free if you want.  I'm down in the Minneapolis area.  Let me know if you would like some as they are just gathering dust right now.
« Reply #2 on: July 01, 2010, 09:33:01 AM »
Brian, I would be interested in that lead sheet if Chuck doesn't want it.  I don't live that far from you.  I'll send a PM too.
muddog16
« Reply #3 on: July 01, 2010, 09:38:09 AM »
Hey Brian, how did that lead sheeting work on sound proofing your bus?   Was it worth the effort and cost to do it?    Thanks Pat!
Pat
1982 Prevost LeMirage
8V92TA/HT754
chuckd
« Reply #4 on: July 01, 2010, 10:07:59 AM »
Brian, I am all over that offer, I will PM you to arrange the time and place.
Thanks for your generous offer.
Chuckd
PS Need any cherry wood?  Smiley
« Reply #5 on: July 01, 2010, 10:29:08 AM »
I would still be interested in a source for the lead sheets if anyone has such information.
« Reply #6 on: July 01, 2010, 10:37:45 AM »
Roofing supply outfits for outlets start with 1/16 in the rear and go thinner all the way to the front you will have a bus that has no road noise.
FWIW Prevost use lead on the entertainers shell
cody
« Reply #7 on: July 01, 2010, 11:35:13 AM »
Just try to remember to not eat any of the sheets. lol
Just Dallas
« Reply #8 on: July 01, 2010, 12:15:16 PM »
Removed
« Last Edit: July 14, 2010, 06:43:37 PM by Now Just Dallas » Logged
DMoedave
« Reply #9 on: July 01, 2010, 09:28:05 PM »
Scott, you can also get it at plumbing supply stores, it is used for lead pans (showers). It is pricey but most people use viynal sheets now. If you can find ones that are damaged you might get a price break. Go to the older or oldest plumbing store around and ask.
cody
« Reply #10 on: July 01, 2010, 09:34:01 PM »
Dallas, we got satin sheets once many years ago, after spending a couple of nights chasing my pillow I got rid of them and went back to regular cotton sheets lol.  For soundproofing now most use mass loaded vinyl, it's available in several thicknesses and can be bought in rolls, very nice to work with and seems to do a good job.  Concentrate in areas like over the wheel wells and over the engine compartment, road noise and engine noise are the biggest culprits.
« Reply #11 on: July 01, 2010, 10:03:13 PM »
What Clifford said!
Sheet rubber is also a good sound deadener and with the efforts to dispose of old tires the prices seemed to be dropping a year ago.  Given that tires have oil in them I wonder at the possible odor problem.   Any advice on that?
Bob Belter
« Reply #12 on: July 01, 2010, 10:17:05 PM »
Ahoy, Chuckd,
I got a roll of lead sheet from a roofing supply house.  Called 'two pound lead sheet' for 2 lb/sq/ft.  Cost was not bad.
My genset box is a 'sandwich':  1/2" birch plywood,  two layers of 30lb roofing felt, one layer of two lb lead, two layers of roofing felt, one layer of 1/2" birch plywood.  VERY effective.
Enjoy   /s/   Bob
jjrbus
MCI5C/N Ft Myers FL
« Reply #13 on: July 02, 2010, 05:30:25 AM »
I was looking at lead sheeting for my gen compartment and ran into a real problem. I'm really attached to my money and they wanted a large chunk of it for lead sheeting Grin The mass loaded vinyl is  pricey also.  I called several junk opp's recycling facility's.
 One stated that he had a dumpster full of sheeting. I went and it was folded up, but was going under genset anyway. So I bought what I needed, took it home unfolded it and with a 1' 2X8 and a sledge made it flat enough in about 10 minutes. It is very soft and easy to work with.
 If you are looking at $150 worth of sheeting, this method will cost you about $15. It also gave me the opportunity to poke around the stainless scrap and see if there was anything I could use.
        HTH  JIm
« Reply #14 on: July 02, 2010, 05:45:27 AM »
MLV will not hold up to the heat and vibration from a bus and reading the spec it is for sound proofing not sound deadening lead is the best for deadening check the manufacture spec not the suppliers that sell it.FWIW one of the major converters of Prevost got in big trouble using MLV he is no longer around
