January 18, 2018, 12:05:54 PM *
Author Topic: Changing tires with bottle jack  (Read 8129 times)
scotty_vince
« on: July 01, 2010, 12:21:38 PM »
I am planning on switching out the "window makers" on my 4104 this weekend with some 22.5 w&t's. Is this something I can do with a big bottle jack and a breaker bar. If so how big a jack and any special info or tricks would be much appreciated.
« Reply #1 on: July 01, 2010, 01:02:55 PM »
I do this regularly.  What I do as far as jacking is concerned I use three steps.  With the bus aired up I jack under the axle lifting point until the tire is slightly unloaded, then I break loose the wheel nuts.  Take care about left and right threads, and if your tires were put on with a big air-gun and over-torqued, stop now and rethink your plan!   Step two is jack the wheel up about three or four inches clear of the ground, then block the bus chassis.  With the chassis blocked, you can now lower the wheel to just clear of the ground or barely touching, remove the wheel nuts and you now have lots of clearance around and above the wheel to get it out of the wheel well.
I use a 20 ton air operated jack, just because it makes the jacking part so easy.  the smallest jack I would try is a 12 ton, just because I have one and I can barely work the manual lever when it's under the bus.
NEWELL in South Carolina
« Reply #2 on: July 01, 2010, 01:19:58 PM »
15 minites into the job with a manual bottle jack & the air operated jacks start looking really cheap!
The higher capacity jack will be under less stress when in use - but since it will weigh more, you will be under more stress to move it into position.  Undecided So, you need to choose carefully (- if a jack spits out a seal, it is of no use until it is fixed. . . .) My prefrence is to use a jack that is rated at or above the weight of the whole bus - overkill, but usually less effort to actually lift the bus.
Good luck
scotty_vince
« Reply #3 on: July 01, 2010, 02:04:39 PM »
What can I do if the wheel nut is on to tight for breaker bar?
« Reply #4 on: July 01, 2010, 02:49:25 PM »
If the nuts are on too tight, you have to escalate your game.  My driver's side were all way overdone when i got my bus, at the end of the day I used a Snap-on 1" drive impact with the air pressure dialed up to 140 psi.  If you don't have such a tool, or the means to make up a 10 foot extension that won't break, my advice is to simply call a mobile tire service and have them take the wheels off for you.  Or drive your bus to a tire shop you trust, have them break the nuts loose and re-torque correctly.  After you install them and torque them correctly with your tools, you will never have the problem again.
There is a tool on E-bay that uses planetary gear ( I think) torque multiplication to take off wheel nuts, and it has gotten good reviews, but I don't have a link to it.
scotty_vince
« Reply #5 on: July 01, 2010, 04:17:23 PM »
I think I'm going to hire someone to take them off. After all that how tight should I torque them and what's "best" way. Thankyou for the help.
edvanland
« Reply #6 on: July 01, 2010, 05:30:03 PM »
Scotty
My only tool to remove or change a tire is a cell phone.  Most of us, I am 70, do not need to do this if at all possible. My back and heath are more important than a few dollars.
My 2 cents worth.
ED
Ed Van
Cornville, AZ
scotty_vince
« Reply #7 on: July 01, 2010, 06:13:41 PM »
I am 35 and have more health than wealth. But thanks for the advice I think your method is much much more appealing than mine.
« Reply #8 on: July 01, 2010, 06:31:15 PM »
Make sure that the nuts are NOT tightened with a impact gun.  I caught one jerk twisting the nuts on with a air hammer and then he put a torque wrench on the nut and leaned on it till it "clicked".  I watched him tighten(over) every blessed nut and then I stepped in and asked him to "verify" he torque needed to "break the nuts loose".  When he reached for the air I said "oh no, Amigo.  Use the torque wrench, I want a number".  The manager got involved and the wasted shop hour was mentioned repeatedly. Make sure you aren't in the same shape after this is over.  You should be able to break them loose and re-tighten them with out difficulty.   Each of them cause one stuck might as wel be all of them.
The HF air over hyd bottle jack goes on sale periodically and it is 40% off.  I have one and recommend it highly.
Melbo
MC8 under construction
« Reply #9 on: July 01, 2010, 06:37:42 PM »
I broke my bolts loose with a 1" breaker bar and an extension -- I took a 2 by 8 and drilled a hole at the level of the bolt and put the extension through the hole and set it on the ground -- put the socket on the nut and the breaker bar on the extension.  I slipped an 8 foot pipe over the breaker bar handle and pulled it down.  The 2 by 8 kept the socket lined up and the pipe gave me the leverage necessary to beak the nuts loose.  I hope this makes sense -- it worked so well (and I am pretty old and kind of small) that I packed the 2 by 8 and pipe in the bays in case I need them on the road. The 2 by 8 has a series of holes that will do for most positions the lug nuts will be in.
HTH
YMMV
Melbo
« Reply #10 on: July 01, 2010, 07:25:19 PM »
As noted, a busnut should only have to do this once, the first time, then never again.
Do not let anyone put your wheel fasteners on with an air gun.
Period.
This is one physics application that is simple.
You need 500 foot-pounds on the typical stud or hub piloted bus wheel.
Your weight, hung the calculated distance out a bar from the socket, to make 500 pounds.
So, a 200 pound person, places their hands on the bar 2 foot 6 inches out on a bar, leans on it and gently raises knees and toes off the ground... makes 500 foot-pounds at the fastener.
A caution: if your studs have been abused by the previous owners, they may not maintain torque, a fancy way of saying they will loosen off, and need to be replaced.
Every busnut should consider replacing all of their wheel studs at some point, so they know exactly what has and has not been done to them.
« Reply #11 on: July 02, 2010, 05:34:16 PM »
Be very careful jacking anywhere on the body. I jack the axle only and block the air bag suspension at the rubber bumper. I don't trust that old Al body at all.
I have one of those torque multipliers and it works like a charm, 58:1 multiplication.
Usually a 6' pipe on a four way lug wrench will loosen any nuts.
I agree, don't let the tire shop use the monster air wrench on your wheel.
I just finished replacing all the lug bolts of my 4104 RR rear hub because all the threads were stripped. Now I tighten them myself with a small 1/2" air wrench not capable of overdoing it.
The 4104 calls for 400 to 500 lb-ft as I remember, check your manual.
« Last Edit: July 02, 2010, 05:36:29 PM by gus » Logged
PP
Will & Wife
« Reply #12 on: July 02, 2010, 07:23:57 PM »
Scotty, or anyone else that is interested in jacking up a bus equipped with air bags, I air the bus up to the max height and set wood blocking under it. Then I let the air down until she is setting on the blocking. Now all I have to do is jack up the axle that I'm working on and a 12 ton bottle does it with ease. My 12 to 1 torque multiplier easily removes the lug nuts with only a 1/2 inch drive breaker bar and I reinstall using the multiplier and a torque wrench set at 40 pounds. I've never had a lug come loose between checks FWIW.
Hope this helps, Will
It's all good  Grin
Mrbill4108
« Reply #13 on: July 03, 2010, 05:06:29 AM »
To remove the tires off our bus I bought and use the Ken Tool Power Wrench TR44X (34545) Budd-Wheel Power Wrench.  It works well and I have never found a lug nut it wouldn’t loosen.
Just did a search on the net and found it here…
http://www.handsontools.com/Ken-Tool-TR44X-Budd-Wheel-Power-Wrench-Set_p_12635.html
It’s a bit pricey, but to be able to R&R a tire anytime on the road or at home I think it’s worth it.
Now if you think you’d like be able to change a tire also, went to the tool show here and Ken Tool just came out with a new tool for demounting big tires, they call it Cobra P/N 35440.  Watched it in action and was amazed how easy it was to use.   Wish they had it back when I bought their Serpent tire tools.  Which by the way the Serpent has worked well for me for many years now, takes me less than 5 minutes to demount & mount a tire on my aluminum rims (12Rx22.5).
http://www.handsontools.com/Ken-Tool-35446-Super-SerpentTM-5-Piece-Tire-Changing-Set_p_12504.html
See the Serpent in action:
Ken-Tool's Serpent Tubeless Tire Mount/Demount Tire Irons
See the Cobra in action:
Ken-Tool: Blue Cobra Truck Tire Demount Tool
Good luck with your tires,
Mrbill4108
79 GMC 4108A
S/N 228
Florida Space Coast
jjrbus
MCI5C/N Ft Myers FL
« Reply #14 on: July 03, 2010, 06:24:57 AM »
I gave up, I cried uncle, I threw in the towel . No more 40 HP compressors with 10 HP impact wrenches. No more titanium sockets with kryptonite breaker bars and 20 foot cheater pipes. No 5 gallon drums of magic elixir and fire wrenches.
 I don't know what caused me to have to conquer that little chunk of metal, to get it off in one piece regardless of cost or consequence. Some form of insanity maybe?
 Now I use an angle grinder with a little finesse. Usually less than a minute and the nut is off! New nuts are cheap compared to broken studs.
                                                       HTH   JIm
