May 26, 2018, 10:31:14 PM *
Author Topic: R & R engine in MCI........at home.....  (Read 2437 times)
ChuckMC8
« on: August 16, 2006, 03:38:11 PM »
OK, I know this may seem silly, but I need the experience of someone in a similar situation who has done this......
Here's what I have, Bus, gravel lot, backhoe. 'Nother eng and trans. Wanna pull whats in the bus and install the other.
   What I wish I had, concrete floor, forklift.......but nooooo......so, all thats left is to get on with it.
 Thought (or plan) #596 is to remove the back doors and bumper, of course, and then jack and block the engine cradle just untill it clears the rails, and then release the brakes on the bus and pull the bus forward and just leave the back end of the cradle on the rails and then block up the rear of the cradle ( pulley end)....
 Is there a better way with the facilities and equipment that I have? thanks Chuck
Stan
« Reply #1 on: August 16, 2006, 05:21:47 PM »
Is your hoe bg enough to handle a stinger on the bucket? It would be a lot safer if you could lift the engine with chains attached to the stinger.  It is always risky to trust a graveled area to support a concentrated weight such as an egine sitting on blocks.
ChuckMC8
« Reply #2 on: August 16, 2006, 06:22:41 PM »
The gravel isn't a deal...it's on Georgia red clay that's cut (instead of filled) with 4" compacted crusher run compacted on top......and, its mostly cut Isenglass rock (what we call it here in the grading b'ness)  I can put my bottle jack on the gravel and jack up the bus.....(I dont routinely do that, but it will support the jack)
Dry, Ga. red clay is hard as concrete...wet, its slick as snot.....with the gravel on it, it doesnt matter.
But gravel over topsoil or fill, you're absolutely right, it wouldn't be safe........but here its fine
Tom Y
« Reply #3 on: August 16, 2006, 06:30:56 PM »
[Chuck,  Heres what I did.  I have a 5C, I set the bucket near the engine and used a come along to slide back.  Pulled back to close to tipping point. Then used front bucket to lift out, drove up behind bus.  Hope this helps.  Tom Y
Tom Yaegle
Hartley
« Reply #4 on: August 16, 2006, 08:35:54 PM »
1/4 " steel plate, Probably a couple of sheets laid down under where the bus will be sitting.
as long as you have a firm base for the plates to lay on you should be able to jack up the mess, block
it in place and slip the bus forward. ( once you figure out how to release the brakes....)
One note. if you air up the bus to release the brakes the air bags will pick up the whole affair.
Maybe airing up before jacking and blocking, then when the air goes down it will lift the engine...
Lot's of catch 22's there too....
I did it twice on a PD4501 and twice on an RTS but that wasn't an MCI...different setup..... Embarrassed
