January 16, 2018, 11:37:04 AM *
Author Topic: Loose Lug Nut indicator  (Read 5133 times)
James77MCI8
« on: July 05, 2010, 06:54:16 AM »
Just passing along some info I stumbled across.
http://www.wheel-check.com/
77 MCI 8
8V-71 4 spd
HB of CJ
« Reply #1 on: July 05, 2010, 02:51:11 PM »
When I worked for the Fire Department a long time ago, the Master Mechanic had us paint little fine black lines on the silver painted lugnuts and red painted steel wheels sosss he (or us) could tell if any nuts (on the wheels!) had worked loose.  Seemed to work then.  HB of CJ (old coot)
c-coop
« Reply #2 on: July 05, 2010, 02:53:31 PM »
just do like me , put a small mark with a marks-a-lot on one side of the nut to the wheel. I check mine regularly
« Reply #3 on: July 05, 2010, 02:58:23 PM »
I see these all the time on cement trucks and some straight trucks.  First Transit also uses these on their transit buses and some coach buses around here have them.  They don't exactly add to the look of the bus, but it certainly makes it easier to be sure lug nuts aren't coming loose.
The marker on the lug and nut is free and won't be so noticeable.
« Reply #4 on: July 05, 2010, 06:53:51 PM »
On white wheels a loose nut will cause a rusty streak outboard from the nut.
I just mark with a paint pencil or laundry marker pen, works well.
Songman
« Reply #5 on: July 06, 2010, 06:10:46 AM »
I looked at those and thought about offering them in my store but passed because bus nuts didn't much like the looks of them. What impressed me about them is that they are also made to melt above normal operating temperatures that would indicate a brake or hub problem. Can't do that with an ink mark. Maybe if they came in different colors it would be more appealing.
1992 Prevost XL-45
Nashville, TN
« Reply #6 on: July 06, 2010, 06:12:27 AM »
you have to carry spares, if you try to take them off in cooler weather they tend to break.  I have them on my bus, they are ugly as ugly can be, but they do a job.
« Reply #7 on: July 06, 2010, 07:10:31 PM »
Here's the next generation of those nut pointers:
http://www.spectraproducts.ca/Products/ZafetyLugLockTM/tabid/72/Default.aspx
The trouble is, you already have a loose nut, and have to notice it, with the originals. This newer product prevents the nuts from rotating from wherever they were when the plastic is slipped over it.
Andy is the guy to talk at Spectra, tell him that guy from the transit with the converted coach sent you.
