Wax-um
Offline
1982 MCI Conversion project
« on: July 06, 2010, 05:16:57 PM » |
Anyone know were I can purchase aluminum rear wheels for my MCI 9.
« Reply #1 on: July 06, 2010, 05:35:28 PM » |
most just run them on outer dual..ck out simulators;ch out e-bay usually several used repolished there..if you going to run 12R22.5 I pretty sure you will need 9 inch wide wheels..Bob
Bob@Judy 98 XLE prevost with 3 slides --Home done---last one! SW INdiana
Wax-um
Offline
« Reply #2 on: July 06, 2010, 05:47:36 PM » |
I will definatly consider simulators. My biggest concern is buying a set of wheels or simulators that will fit correctly. If anyone can confirm fitment than I could sure use some help sourcing a set of wheels or simulators for my 82 MCI. For simplicity I maybe better off getting sims for I dont have to take bus in for remounting.
« Reply #3 on: July 06, 2010, 05:49:34 PM » |
9 inch alum wheels are premium price..simulators for bud wheels is what you want.
NCbob
« Reply #4 on: July 06, 2010, 05:58:03 PM » |
There's a difference between Hub piloted wheels and stud piloted wheels. The trucks use the hub piloted type but our buses use the stud piloted type.
As always be sure of what you're buying before you spend your money.
NCbob
« Reply #5 on: July 06, 2010, 06:07:41 PM » |
We all will admit that the aluminum wheels look awesome but for cost amounts, durability and in all reality the simulators are probably the way to go. Do a search on the net or Ebay and see what you can find. Later
Seven Heaven.... I pray a lot every time I head down the road!! Bad decisions make good stories.
« Reply #7 on: July 06, 2010, 06:23:55 PM » |
I am not real keen on simulators, or any kind of covers, because you should be able to look at, and feel with your hand your wheels, so you can spot loose nuts, and hot hubs (bad bearings). So for me, it is either steel wheels, they can look quite nice painted your choice of color, or aluminum (Alcoa), in various stages of polish, or, in my case, neglect.
JC Invermere, BC 1977 MC5C, 6V92/HT740
flynbanjo
« Reply #8 on: July 06, 2010, 07:17:25 PM » |
I bought a set of Alcoa wheels (size 22.5 X 8.25) from Youngstown Kenworth in Youngstown Ohio. 800-321-2056. They will ship them. If I remember correctly they were under $300 each.
Steven 81 MCI MC9 Hudson, Florida
« Reply #9 on: July 07, 2010, 04:48:21 AM » |
what size tires you running?(makes diff on rim width)I know where there is a stack of alum wheels,they would be 8.25 wide..would fit your bus ,they have 11R on them now..Bob
txjeff
« Reply #10 on: July 07, 2010, 05:19:19 AM » |
Wax-um
I sent you a PM, the simulators I have should fit your wheels.
Jeff
73 MC-7combo Brenham, Texas
« Reply #11 on: July 07, 2010, 05:36:57 AM » |
Yeah, but he won't split up the set. I wanted to buy 6 but he wouldn't sell me just 6. it was all of nothing. interesting that he still has them. that was several months ago.
Songman
« Reply #12 on: July 07, 2010, 07:55:27 AM » |
I guess I can see that. It's easier to sell a full set. Especially since they are the ovals. Not everyone is running them so ones and twos might be hard to get rid of. I don't know for sure he still has them. Last time I talked to him he did. But he is a truck driver so very rarely home.
« Reply #13 on: July 07, 2010, 11:34:20 AM » |
Nothing looks better and has easier upkeep than white painted steel wheels.
Al looks great but the cost and upkeep are not worth it.
Personal opinion, of course!!
PD4107-152 PD4104-1274 Ash Flat, AR
« Reply #14 on: July 07, 2010, 11:43:30 AM » |
I can get brand new powder coated wheels here in a few different colours, Accuride, for $115 each. I'm thinking black powercoat 5 hole wheels would look good!
No one mentioned studs. you sometimes have to change the studs for aluminium wheels, although I think that if you run steel on the inside of stud centric Budd's the studs are OK, you may have to change to longer cones and different outer nuts. something to find out for sure.
1980 MCI MC-5C converted Vintage race cars - 1978 Lola T440 Formula Ford 1972 NTM MK-4 B/SR
