June 21, 2018, 05:45:15 AM *
Author Topic: Reinstalling Starter  (Read 5868 times)
« Reply #15 on: July 28, 2010, 05:29:03 PM »
Thanks for the help.  It is back in now.  I tightened the bolts as much as I could with a standard 3/8" ratchet.  I doubt there is any way my puny self could have over-torqued it with such a small tool.  I did give them a little snug with a small extension.  I will monitor them too see if they begin to loosen.  Normally, this would not have been a question, but since that had been put on so tightly just a few hundred miles ago, I thought that maybe that was required.
Anyway, after trying to trace the starting hesitation through the whole system, I finally got to tackling the starter, which was the problem.  I was pretty sure of that when I noticed that one of the lead battery terminals was melting probably from a ridiculously high amperage draw.  I started it up a couple of times to test it, and it sings.  Maybe we can get some trouble free use in for a while now.
jjrbus
MCI5C/N Ft Myers FL
« Reply #16 on: July 28, 2010, 05:47:26 PM »
Would a "Thread lock" type product made it that hard to get out Huh   JIm
« Reply #17 on: July 28, 2010, 08:08:43 PM »
It all depends, there are many types of thread lockers for many sizes, uses and temps.
« Reply #18 on: July 30, 2010, 09:11:25 AM »
Quote from: jjrbus
Quote from: gus
What Gus said! As long as "Loctite" and other such products are properly matched for their intended application they are great! What is a real PIA is when someone uses the wrong stuff and it can actually cause damage removing a bolt after word! They make all kinds and all have labels saying the size bolts, intended torque range, heat range, as well as a general use description! Use the right stuff and "no worries!"
FWIW Grin  BK  Grin
NEWELL in South Carolina
« Reply #19 on: July 30, 2010, 11:08:20 AM »
Some thread-loc compounds require heat (up to 500F) to safely remove.
« Reply #20 on: July 30, 2010, 03:55:13 PM »
Just to keep things straight, these bolts did not have any thread lock on them.  The person that tightened them said that he is sometimes known for getting things really tight.
« Reply #21 on: July 30, 2010, 07:40:17 PM »
I'd be really hesitant to put any thread locking compound on starter bolts.
How you gonna get 'em out next time?
There are precious few places a busnut needs to resort to Loctite.
The 4 little screws for the fan on your big air-cooled Delco might be one place... but otherwise, best go real easy with that stuff.
« Reply #22 on: July 31, 2010, 03:22:47 PM »
Some loctite requires very little torque to loosen, it all depends on what you use. It is never a good idea to just pick up a tube and use it without knowing its specs, there are many, many different kinds.
I think loctite is very useful because these old guys vibrate so much, stuff is always coming loose on my oldie (1954).
I have a stout son-in-law who can install nuts I can't get loose, he probably breaks a few along the way!!
NCbob
"Foolish Pleasure" 35' MC5A
« Reply #23 on: August 01, 2010, 10:01:58 AM »
I was happy to read this thread as I have to have my starter pulled for rebuild. Unable to do it myelf as I just got out of the Hospital with a brand new complete left hip on Saturday. But after it's been repaired I'm hoping to do the re-install. I'll be able to put a lot more torque on that mammy-jammer now!
NCbob
« Reply #24 on: August 01, 2010, 11:00:17 AM »
NCbob
Bob glad to hear from ya again, good luck and great to hear you'll be get'n around better soon too!
« Reply #25 on: August 01, 2010, 11:09:45 AM »
Bob,
Hope your recovering goes well.  I really was not sure I wanted to do the R and R on the starter, but cheap as I am, I did it.  It is easy to get to and straight forward but heavy.  I sometimes contemplate whether it is better to pay a mechanic or a doctor.  Anyway, it was decided for me since the local auto electric place's price for starter and labor were out of line, so I removed it myself to take it elsewhere.  Anyway, at least gravity was on my side in the take out.  Putting it back was different.  I used a combination of a sling and levers to get it in, but if you have a floor jack, it would be much easier.
jjrbus
MCI5C/N Ft Myers FL
« Reply #26 on: August 01, 2010, 07:55:23 PM »
Unless you are 20 year old line backer, rolling floor jack is very necessary tool for reinstalling starter Grin  JIm
« Reply #27 on: August 01, 2010, 07:58:28 PM »
At the risk of sounding like a one-trick pony let me again put in a plug for the Delco 39MT series of starters.  I can't actually one hand mine at full arm sideways extension but I'm sure some of you could.
« Reply #28 on: August 03, 2010, 09:45:38 PM »
39MT is great as long as you have a right handed rotation engine.  At Freightliner, the servicing of these jewels is alot more frequent then the old MT41 or 42.  If you can heft the weight, I would stick with the old tried and true MT41.  Good Luck, TomC
