May 22, 2018, 06:06:58 PM *
Author Topic: More Insulation Picts  (Read 1383 times)
« on: July 31, 2010, 10:10:09 PM »
Not quite used to this.. TomC
« Reply #1 on: August 01, 2010, 08:08:55 AM »
As a testiment to the insulation, I was working inside yesterday (sealing the cracks with white mastic roof sealer [like really thick paint]) in 90 degree weather and that one 10,000btu portable A/C kept it quite comfortable inside.
CS
« Reply #2 on: August 01, 2010, 09:30:35 AM »
how thick is the insulation? what is the density?
« Reply #3 on: August 01, 2010, 05:58:35 PM »
The insulation is 2.25" thick.  It is sprayed on two part insulation, so pretty stiff.  Don't know the density, but there can't be much around that is more dense then this insulation.  Good Luck, TomC
