January 17, 2018, 06:37:54 AM *
Author Topic: tricks to removing factory MCI windows?  (Read 1857 times)
« on: August 11, 2010, 10:22:51 AM »
My new Peninsula windows are now here, and before I go out and screw something up, I wanted to ask if there are any tricks to removing the factory top hinged windows from an MC-5C.  The emergency release bars still work, the windows hinge up and down just fine.  Do I just tap our the hinge pin, do I need to cut anything, do they unhook in anyway?
The Pen windows are installed inside the factory frames to replace the OEM glass, basically.
Thanks, Brian
« Reply #1 on: August 11, 2010, 11:16:04 AM »
Brian, if it is anything like the D model, open the window to about +- 45 degree angle, then lift it up and out. Two people make it easier. Take a good look at the hinge first and you'll figure it out. The hinge is shaped like a C, and when openned to the rigth angle, just unhooks.
Blackie AB
« Reply #2 on: August 11, 2010, 11:49:52 AM »
That's kinda what I was thinking and hoping!
Thanks, Brian
« Reply #3 on: August 11, 2010, 03:37:12 PM »
We had our 5A done at the factory and i helped. Its been a few years but i think we had to pull/drive out the pins. It does take two to do it.
