May 24, 2018, 03:17:37 AM *
Author Topic: cargo bay slides  (Read 2681 times)
twocnusa
« on: August 11, 2010, 01:37:54 PM »
i am looklng for cargo bay slides. the only ones i have seen so far are slidemaster. are there others out there? names and locations please. thanks ron mead
« Reply #1 on: August 11, 2010, 01:55:39 PM »
I just ran out to look at mine. They are: "Rolling Cargo Bed". From Edmonton, AB. 403-451-7736. They are really solid and well built. I don't know where you are at, it might be a long way from you... My PO was from Edmonton.
IMO they have pros and cons: it is nice to pull them out and have handy access to your stuff. Mine are 8 foot long.
However the thickness of them makes for a substantial waste of space. My bays have a 3/4" plywood + carpet, then the slides that have a 3/4" plywood tray on them. Total thickness is almost 5 inches. I am almost thinking about removing them.
Blackie AB
« Reply #2 on: August 11, 2010, 02:20:46 PM »
Joey Bed Portland Or and there others like the pickup sliders that also work
« Last Edit: August 11, 2010, 02:22:59 PM by luvrbus » Logged
DebDav
« Reply #3 on: August 11, 2010, 03:38:44 PM »
Try
www.slimslider.com
Bill B /bus
« Reply #4 on: August 11, 2010, 04:06:37 PM »
Make your own. KV has heavy duty slides, 500lbs. 36" was $160/pr. Steel to mount to floor and steel for frame $40. Plywood for bottom $scrap. Welding $25. Paint <$10. Screw and bolts <$10. So for less than $250 I have a 36" deep by 24" wide slide for tool boxes.
I looked at a full bi-directional slide. After initial "Wow that would be neat!" I thought about nothing higher than about 23" to clear tunnel of the MCI.  Then the thought of a loss of 4" of that height due to slider itself. Hmmmmm. Even if I built it myself it was still going to cost about $6-800. Still thinking.
Bill
Bill & Lynn
MCI102A3, Series 50 w/HT740
stevet903
« Reply #5 on: August 11, 2010, 04:40:46 PM »
Accuride also makes heavy duty slides if you want to roll your own...
http://www.accuride.com/Woodworking/Product/Details.asp?ProductID=63
Steve
crown
« Reply #6 on: August 11, 2010, 04:42:21 PM »
 i found roller slides at a salvage metal place and built my own cost was under $ 100 for 10 bay slide i did 1/2 bay per side plus one like
 a bunk bed   crown
john
 57 crown
 costa rica
crown
« Reply #7 on: August 11, 2010, 04:44:57 PM »
a few more pics of building the slides crown
john
 57 crown
 costa rica
happycamperbrat
« Reply #8 on: August 12, 2010, 04:11:27 PM »
for diy slides, Mike told me that roller skates would be good rollers and yes I agree!! Additionally for the channel, garage door frames work and today I noticed that aluminum blinds have STEEL at the top. I don't know how much weight they would hold, but my thrift shops are full of these and it would be pretty easy to put roller skates in them.....
Ray D
« Reply #9 on: August 12, 2010, 09:37:54 PM »
Roller skates that fit into guides and slides......... am I the only one here that sees a new Vegas casino jump?
Ray D
