May 28, 2018, 03:10:38 AM *
Author Topic: battery question  (Read 2326 times)
centrix29
Prevost Proud
« on: August 22, 2006, 07:51:32 PM »
My friend gave me 8 4D Lifeline (sealed type) batteries.  I have a 3000W inverter.  I am looking for a battery charger that could charge my batteries. How should I configure the charger with the batteries and the inverter?  I am running an electric fridge, a TV and lights on the inverter.
Thank you for your help!!!  Smiley
Pat
Moof
« Reply #1 on: August 22, 2006, 09:14:10 PM »
I've posted this link before.  There is a lot of information in it.  I hope this gets you going in the right direction.
I would compare this information with the information that came with your inverter.   Good Luck!!!
http://www.equalccw.com/hardcore.html#INVERTERS
« Reply #2 on: August 22, 2006, 09:39:13 PM »
Here's directly from Lifeline.  3 stage charger- Bulk 14.2-14.4 volts; Acceptance 14.2-14.4 volts; Float 13.2-13.3 volts.  Equalize after fully charged at 15.5 volts for 8 hours (only if showing symptoms of capacity loss).  State of charge- 100% 12.8 volts or more; 75% 12.55 volts; 50% 12.2 volts; 25% 11.75 volts; 0% 10.5 volts.  Lifeline recommends sizing batteries twice what you need and recharge when at 50% and recharge 100%.  I have 2-8D's and am very satisfied with them.  I have my three stage set like above pumping in 85 amps at 12v. at the beginning.  They should easily last 5 years.  Good Luck, TomC
TomCat
It's 4:20 somewhere...
« Reply #3 on: August 23, 2006, 08:36:19 AM »
My Xantrex RS3000 does not enable equalize mode when set to AGM type battery.
Jay
87 Saftliner
« Reply #4 on: August 23, 2006, 09:51:39 AM »
Hi Pat,
You might want to keep your eye out for a Inverter/Charger combo setup to elaveate the clash between invert and charge cycles with two different
components trying to work together. I also have the RS3000 Sinewave networked Inverter from Xantrax but, I have flooded led acid batteries and I
utilize the equalize feature. and all works as designed..
