May 25, 2018, 03:39:48 PM *
Author Topic: Detroit 6v92T set up  (Read 2806 times)
eagle10
« on: August 27, 2006, 05:46:11 AM »
Would I run into any issues if my 6v92T were set up from 2150 to 2300? Ideas?
« Reply #1 on: August 27, 2006, 05:52:37 AM »
I run the 8V92 in my Eagle 10 at 2300 rpm for at least 100,000 miles with no problem. This was full load governed rpm. I seldom run it that fast, but did run in the 2200 rpm up a lot of grades. I do not know what the top speed was but I could bury the speedometer at 80 and still had more left.
Happycampersrus
« Reply #2 on: August 27, 2006, 06:38:03 AM »
It won't cause any problems. The only time you would have to worry is if you were to go much above 2500.
Dale
