June 20, 2013, 03:45:26 AM *
Author Topic: Off the wall electrical question  (Read 841 times)
wal1809
« on: September 28, 2010, 04:50:41 PM »
I don't know if they make it but i am looking for a relay.  The one I am looking for will operated by 12v on off switch allowing or not allowing 110v to a pump.  If you know they make them or well them please let me know.  I'll thank you in advance.
www.snakebreaker.com
« Reply #1 on: September 28, 2010, 05:32:47 PM »
Thousands of them.
Need to know how many amps or watts the pump draws on start-up to give you a more exact reference.
WEC4104
« Reply #2 on: September 28, 2010, 05:40:07 PM »
Sounds like something similar to a project I installed years ago.   I have a 12 VDC switch on my dash. It is wired to a solid state relay at the rear of the bus that controls the engine block heater (110 VAC).   I used a Crydom TD1225 solid state relay.   The input side accepts 3 - 32 V Dc to close the circuit on the output side (maximum of 25 amps.)   Works like a champ.  I mounted the relay inside a standard sized electrical outlet box.
On cold mornings I used to have to go outside, walk to the back of the bus, open the tailgate and plug in a cord.  Now, from the warmth and comfort of the bus, I just flip the dash switch.
« Last Edit: September 28, 2010, 05:43:57 PM by WEC4104 » Logged
wal1809
« Reply #3 on: September 28, 2010, 07:46:42 PM »
Thousands of them.
Thank you Sean!  I will get the info on the pump tomorrow.  It is a small half horse
power blue 1 inch clear water pump from harbor freight.  I intend to use a 12 volt switch on the dash to a relay to give 110 volt power to the pump.  The pump will be used maybe 4 minutes per hour of drive time as it will transfer oil from the 100 gallon oil tank to the 22 gallon heated tank at the rear of the bus.
wal1809
« Reply #4 on: September 30, 2010, 06:17:21 PM »
Thank you Sean, I went by Granger today and ordered the part.  I beleive this is going to work.
wal1809
« Reply #5 on: September 30, 2010, 06:21:31 PM »
Now this post was a piece of shear genius.  I do hope you don't mind me copying your engineering!
