May 26, 2018, 02:37:16 PM *
Author Topic: A distant Memory of the Old MAK Board...  (Read 4064 times)
« on: August 28, 2006, 07:10:39 AM »
What a difference we have all expierenced since the new board has evolved. Even I, have forgotten how limited the old board was.
Cheers to Mike, Phil, and our team of Moderators for making it possible for what we have now!
Nick Badame
Here is a look at the final day's of the old Board....Sad...
Amsoil bypass oil filter - Wayne 19:11:00 04/08/06 (2)
Re: Amsoil bypass oil filter - Dallas 19:53:24 04/08/06 (0)
Re: Amsoil bypass oil filter - Gary Stadler 19:27:58 04/08/06 (0)
Bus Convention - Kenny D. 09:19:04 04/08/06 (1)
Re: Bus Convention - ceieio 09:41:07 04/08/06 (0)
Charging House and Starting Batteries - Fred Mc 20:41:47 04/07/06 (16)
Re: Charging House and Starting Batteries - Dallas 18:45:57 04/08/06 (0)
Re: Charging House and Starting Batteries - Jerry Liebler 18:30:01 04/08/06 (1)
Re: Charging House and Starting Batteries - Gary Stadler 16:56:25 04/08/06 (0)
Re: Charging House and Starting Batteries - Gary Stadler 16:51:29 04/08/06 (1)
Re: Charging House and Starting Batteries - Marc Bourget 14:51:43 04/08/06 (4)
Re: Charging House and Starting Batteries - Jerry Liebler 09:43:10 04/08/06 (0)
Re: Charging House and Starting Batteries - Jerry Liebler 09:42:14 04/08/06 (5)
Re: Charging House and Starting Batteries - Geoff 09:00:07 04/08/06 (0)
Re: Charging House and Starting Batteries - Gary Stadler 08:36:25 04/08/06 (1)
Re: Charging House and Starting Batteries - Dallas 06:28:14 04/08/06 (0)
Re: Charging House and Starting Batteries - Marc Bourget 06:10:04 04/08/06 (1)
Re: Charging House and Starting Batteries - Jim Robinson 03:56:33 04/08/06 (1)
Re: Charging House and Starting Batteries - gusc 18:55:21 04/08/06 (0)
Re: Charging House and Starting Batteries - JohnEd 23:49:39 04/07/06 (1)
Re: Charging House and Starting Batteries - Geoff 03:41:09 04/08/06 (0)
Re: Charging House and Starting Batteries - Geoff 22:55:56 04/07/06 (2)
House battery cables - Pat Rac 17:54:51 04/07/06 (1)
Re: House battery cables - Marc Bourget 06:24:01 04/08/06 (0)
rubber for bay stg. doors - toyznstuff 16:35:46 04/07/06 (6)
Re: rubber for bay stg. doors - 16:37:27 04/07/06 (5)
Re: rubber for bay stg. doors - gusc 18:29:21 04/08/06 (0)
Re: rubber for bay stg. doors - gusc 21:14:28 04/07/06 (1)
Re: rubber for bay stg. doors - 21:12:15 04/07/06 (2)
Re: rubber for bay stg. doors - sam phillips 20:46:13 04/07/06 (0)
Re: rubber for bay stg. doors - sam phillips 20:38:39 04/07/06 (3)
rear view window - old allegro 04:30:55 04/07/06 (4)
Re: rear view window - Steve C 11:17:59 04/07/06 (0)
Re: rear view window - 11:08:26 04/07/06 (0)
Re: rear view window - 10:05:54 04/07/06 (1)
Yes it can be done. - Jay Gerlick 16:12:28 04/07/06 (0)
Power Steering Pump Problem - Steve C 04:19:36 04/07/06 (4)
Re: Power Steering Pump Problem .....mine too - mj 13:24:34 04/08/06 (0)
Re: Power Steering Pump Problem - Busted Knuckle 11:27:27 04/07/06 (1)
Re: Power Steering Pump Problem - TomC 08:00:39 04/07/06 (0)
Re: Power Steering Pump Problem - Casper4104 05:16:03 04/07/06 (0)
House batteries - Eagle 10 (Freebird) 06:41:28 04/06/06 (14)
Re: SAVE COLD instead - FAST FRED 03:30:52 04/08/06 (0)
A Bit of Brain Damage-Let's Try This Again! - TomC 19:40:37 04/06/06 (4)
Re: A Bit of Brain Damage-Let's Try This Again! - Jerry Liebler 19:54:58 04/08/06 (0)
Re: A Bit of Brain Damage-Let's Try This Again! - NewbeeMC9 12:24:46 04/07/06 (0)
Re: A Bit of Brain Damage-Let's Try This Again! - TomC 08:07:00 04/07/06 (0)
Re: A Bit of Brain Damage-Let's Try This Again! - Freebird 07:50:20 04/07/06 (3)
Re: House batteries - 10:42:48 04/06/06 (0)
Re: House batteries - Eagle 10 (Freebird) 10:34:49 04/06/06 (1)
Re: House batteries - Eagle 10 (Freebird) 10:55:37 04/06/06 (0)
Re: House batteries - TomC 07:22:00 04/06/06 (2)
Re: House batteries - Jerry Liebler 08:03:25 04/06/06 (0)
1,100 watt reefer - TomC 07:28:22 04/06/06 (0)
Re: House batteries - Jerry Liebler 07:12:04 04/06/06 (1)
Re: House batteries - Dallas 07:31:27 04/06/06 (0)
a/c ducts - old allegro 22:28:33 04/05/06 (3)
Re: a/c ducts - 06:21:03 04/06/06 (1)
Re: a/c ducts - Nick Badame Refrigeration Co. 06:22:19 04/06/06 (0)
Re: a/c ducts - gumpy 05:00:11 04/06/06 (0)
Amidship Door - Oilfinder 12:08:49 04/05/06 (9)
Re: Amidship Door - Merlin 08:55:54 04/08/06 (0)
Seeking adjustable driver's seat base (air ride???) Anyone know where i can find this? Maybe used? - DROdio 10:36:58 04/05/06 (7)
MCI 7door seals - gabby 10:21:21 04/05/06 (1)
Re: MCI 7door seals - Frank 12:14:05 04/05/06 (0)
Fuel Preheater? - Rick Brown in Reno 09:04:37 04/05/06 (5)
Re: Fuel Preheater? -- Thanks - Rick Brown in Reno 08:19:00 04/07/06 (0)
Re: Fuel Preheater? - DrivingMissLazy 05:37:27 04/06/06 (0)
Re: Fuel Preheater? - Jerry Campbell 19:09:46 04/05/06 (0)
Re: Fuel Preheater? - Dallas 10:45:39 04/05/06 (0)
Re: Fuel Preheater? - gumpy 09:44:23 04/05/06 (1)
radiators - onemule 23:47:14 04/04/06 (6)
Re: radiators - JohnEd 00:11:47 04/08/06 (0)
Re: radiators - FAST FRED 04:04:55 04/06/06 (0)
Re: radiators - Dallas 04:24:58 04/05/06 (0)
tire source in central VA - Kevin 14:41:35 04/04/06 (2)
Tires in Victorville, Ca - TomC 15:56:04 04/04/06 (0)
Re: tire source in central VA - Nick RTS II 15:28:56 04/04/06 (1)
Re: Tire source in Denver - Dallas 12:10:42 04/04/06 (1)
Used Coach Seats - Steve C 06:45:49 04/04/06 (0)
Re: DIGITAL Voltage meter - FAST FRED 04:04:11 04/05/06 (0)
Re: House Battery - Kent 18:08:51 04/04/06 (0)
Re: House Battery - 18:01:08 04/04/06 (0)
Re: House Battery - Phil in SoCal 22:11:37 04/03/06 (3)
left turn signal - dug 17:32:23 04/03/06 (2)
Luke, You are all over it - Dug 18:50:46 04/03/06 (0)
Re: left turn signal - LUKE at US COACH 17:59:55 04/03/06 (1)
Back Up Camera Housing - Jeff 17:08:50 04/03/06 (3)
Re: Back Up Camera Housing - Footloose 07:26:26 04/05/06 (1)
Re: Back Up Camera Housing - DrivingMissLazy 11:38:03 04/05/06 (0)
Re: Back Up Camera Housing - Nick Badame Refrigeration Co. 18:23:07 04/03/06 (0)
83 mc-9 radiators - Busnut83 17:00:15 04/03/06 (5)
Re: 83 mc-9 radiators - 14:04:32 04/06/06 (0)
Re: 83 mc-9 radiators - Jerry H. 19:59:18 04/04/06 (0)
Re: 83 mc-9 radiators - Rich (International Bus Parts) 08:05:38 04/04/06 (0)
Re: 83 mc-9 radiators - Ear-8-Ky 07:22:57 04/04/06 (0)
Re: 83 mc-9 radiators - Ear-8-Ky 07:12:26 04/04/06 (2)
MC 8 Air Beams - Larry Ohlmann 09:52:42 04/03/06 (2)
Re: MC 8 Air Beams - Rich (International Bus Parts) 08:45:45 04/04/06 (0)
Re: MC 8 Air Beams - Jack Conrad 10:18:20 04/03/06 (0)
Stainless Wheel Inserts - Steve C 07:38:44 04/03/06 (3)
Re: Stainless Wheel Inserts - Utahclaimjumper 20:57:28 04/03/06 (0)
Re: Stainless Wheel Inserts - Nick Badame Refrigeration Co. 08:37:49 04/03/06 (0)
Stainless Wheel Inserts - Steve C 07:38:12 04/03/06 (1)
3 way 12 volting lighting control - Pat Rac 18:58:46 04/02/06 (3)
Re: 3 way 12 volting lighting control - Ross 05:53:24 04/03/06 (0)
Re: 3 way 12 volting lighting control - DrDave 05:11:11 04/03/06 (0)
Re: battery acid on metal (preps ?) - gusc 19:57:29 04/02/06 (0)
Re: battery acid on metal (preps ?) - Dallas 17:59:56 04/02/06 (0)
Re: battery acid on metal (preps ?) - niles 16:43:24 04/02/06 (1)
travel lav - Tom Wilkinson 16:25:06 04/02/06 (1)
Bus vs Truck - Ray 15:05:39 04/02/06 (7)
Much better... - gumpy 11:36:15 04/03/06 (0)
contact bigtim44 - old allegro 06:19:17 04/02/06 (2)
Re: Why LIGHT makes you sick? - FAST FRED 03:27:40 04/07/06 (0)
Re: Why plastic line make you sick? - Brian Elfert 14:27:41 04/02/06 (2)
Re: Why plastic line make you sick? - gumpy 14:20:38 04/02/06 (3)
Re: Why plastic line make you sick? - Brian Elfert 11:02:35 04/02/06 (5)
Pumps - Casper4104 09:09:04 04/02/06 (0)
Re: Can I parallel two water pumps for more GPM? - Doug Wotring 12:36:10 04/01/06 (3)
dont leave me out...I can't register..what is wrong - David Pinson 05:09:46 04/03/06 (2)
Re: Lights Going Out on BBS soon / New board - kyle4501 18:47:23 04/01/06 (2)
Re: Lights Going Out on BBS soon / New board - Tom Y 20:47:32 03/31/06 (0)
Fighting bus fires - Jim Shepherd 10:19:28 04/01/06 (0)
Good line... - gumpy 17:08:30 04/02/06 (1)
Re: NEED HELP EAST OF DENVER! - ghanson 20:23:05 04/01/06 (0)
NJ TRANSIT BUSES - JohnEd 22:20:08 03/30/06 (10)
Re: NJ TRANSIT BUSES - 09:17:00 04/03/06 (0)
Re: NJ TRANSIT BUSES - Doug Wotring 06:10:27 03/31/06 (7
Ednj
Ed & Sue Skiba
« Reply #1 on: August 28, 2006, 12:42:39 PM »
I must have been pretty busy working on the bus in April, my name is'nt there not even once. Cheesy Smiley Wink
MCI-9
Sussex county, Delaware.
« Reply #2 on: August 28, 2006, 04:32:22 PM »
Ed,
It was a little more than a weeks worth of messages, You were just into the bus ,for sure LOL Shocked
plyonsMC9
Big Wheels Turnin'
« Reply #3 on: August 28, 2006, 05:23:04 PM »
Hey Nick - that sure brings back some memories.  Some of them weren't, uhm, well, happy.
But did meet a lot of great busnuts!   Grin   Unfortunately, we met almost as many spammers and hackers.   Angry
Now with this board, we are able to fend off the hackers with a few tools.  Makes all concerned much happer   Grin
Except spammers  Angry
Best Regards,
Phil
Northern Arizona / 1983 - MC9
plyonsMC9
Big Wheels Turnin'
« Reply #4 on: August 28, 2006, 09:32:46 PM »
Wow, I didn't even notice that was a week's worth of posts.  We get that many now on a daily basis!
Fred Mc
« Reply #5 on: August 28, 2006, 10:47:02 PM »
I would be interested in a comparison of traffic on the old board vs the new board because, unlike the previous poster, I get the "feeling" there is not as much traffic now.
Fred Mc. PD4106
« Reply #6 on: August 28, 2006, 11:44:17 PM »
I just did some quick calculations.  The new board has been live for about 20 weeks.  This means about 80 new topics a week minus some for topics posted during the testing phase.  The last week of the old MAK board had about 40 new topics, so new topics are up 50% to 100% depending on how many topics were posted during testing.
A few posters have left such as Fast Fred, but it appears he doesn't post on BNO either these days.  Most left because they say the new boards are too slow with dialup, but I know a few don't like the moderation here.  (I don't have any problem with the moderators and they don't seem to do anything if you post on bus topics and don't flame foks.)
The old MAK board absolutely sucked in the last few months.  Phil was rebuilding it alsmost daily at the end so posts disappeared and threading got all screwed up regularly.
Brian Elfert
« Reply #7 on: August 29, 2006, 03:51:59 AM »
Here is the Stats for the new board
Over 25,000 hits a month......Wow.   almost 6 times more than the old board.
 August 2006  303 2511 94 53 245053
 July 2006  342 3112 86 46 267934
 June 2006  401 3644 114 45 279946
 May 2006  328 2688 165 54 244938
 April 2006  320 2690 439 44 227443
 March 2006  26 101 30 15 1816
« Reply #8 on: August 29, 2006, 04:00:51 AM »
Here are more new board stats
Total Members: 921
Total Topics: 1620
Total Categories: 1
Users Online: 7
Most Online: 54 - May 01, 2006, 09:11:18 PM
Brian Diehl
« Reply #9 on: August 29, 2006, 05:58:03 AM »
Just to extend on Brian Elfert's post ....
I really appreciate all the hard work the moderators do on a daily basis on this board.  It is much more pleasurable to use and I really appreciate all of the extras that MAK has so kindly provided for us.
Thanks Mike K., Phil, Nick, BK, and others!
Homegrowndiesel
Vegetable oil, Rudolf Diesel's original fuel
73-05 Eagle
« Reply #10 on: August 29, 2006, 08:05:32 AM »
Good Job folks
Like an old dog, I did not like it at first (different than I was used to) just when I was getting used to the old board.
After some work with it I see how much better I can ues it.
Keep up the good work!  Smiley
Bill Glenn
Aerodynamic Eagle & MCI 102a3, 102d3 and NABI series 50 transit. Busnut x4
plyonsMC9
Big Wheels Turnin'
« Reply #11 on: August 29, 2006, 08:11:37 AM »
Bill Glenn
We're glad to have you aboard Bill!
Kind Regards, Phil
