I enjoyed it too but why didn't you check the bridge clearance ,valves and run the rack you don't just stick injectors in a 2 stroke and forget it sorry if it sounds harsh but that is asking for trouble
Just because you don't see it in the video doesn't mean I didn't do it....
This video is about the replacement of the injector and how I did that procedure. I replaced the N65 injectors with the same.
As seen in the video I did check the injector timing. (all were within spec and required no adjustment)
I did check the bridge and valve lash clearances. (all were within spec)
I did not "run the rack" but I did inspect the movement of the fuel modulating cam and the control tube and it was fine.
I did not feel it needed new crossover fuel lines. But I did make sure none were damaged/cracked while I had them removed and were not leaking before putting on the valve cover.
The video was edited so it would not be too long and be boring. It took longer then is perceived in the video.
I wish it only took 11 minutes per injector...
