January 16, 2018, 01:53:25 AM *
Author Topic: Eden pure heater  (Read 6390 times)
John Z
"Tubby"
« Reply #15 on: October 28, 2010, 09:43:42 AM »
I forgot to mention, i bought mine at walmart. Around here we have Menard's lumber stores, and i see they have a newer model. The case is black instead of gray and it has a remote control. Price at both places is 70.00.
www.silverbrook-mn.com
« Reply #16 on: October 28, 2010, 02:51:25 PM »
Van, it seems that there are different issues here.  One is keeping warm with electricity, and the other is keeping warm without it.  As far as electric heaters go, they are all 100% efficient--meaning that all the energy put in is converted to heat.  100% efficiency is the limit (except for heat pumps in some sense).  So a cheap 1500 watt heater puts out the same amount of heat as an expensive 1500 watt heater.  The comparisons then come down to how well they distribute the heat, how loud they are, how safe they are, etc.  I have found the cheap plastic ones to be great since they are quite, relatively cool and easily moved from place to place.  If you jump from the $20 range to the $60 range, they will have tip over protection, and remote controls that act as thermostats.  However, if you need more than 5000 BTU's none of them will do the job alone.
« Reply #17 on: October 28, 2010, 05:48:37 PM »
Van, you better hurry up and get a heater now that the temps are only in the 80's/low 90's. We don't want you to freeze!  Grin
« Reply #18 on: October 28, 2010, 06:16:49 PM »
Ed, you know I do get a chill, Mom says I need to put on more weight, but that ain't working and even quit smoking (13 days so far, on the patch Wink) so... I think a nice lil' heater should do fine lol.
 Lin, I agree, couple of $20 dollar elec heaters should do nicely, heck only need it 3 months out of the year, tops Grin
Dave5Cs
« Reply #19 on: October 29, 2010, 09:46:42 PM »
I hear the "Wave heaters" are pretty good any of you use them and if so which size. Does it heat the whole Coach or just an Area. How much gas do they use. Are they safe with Cats. Don't want Feline Flambe' Don't YA Know.
Dave
"PATHFINDER"(Bus)
Toed 1998 Jeep TJ
« Reply #20 on: October 29, 2010, 11:19:12 PM »
Olympian heaters are one of the standards in RV's.  They are very efficient for propane use but do use living space oxygen.  Therefore one is instructed to have a window cracked to replace the loss.  They come with oxygen sensors as a safety to shut them down if the level falls too much.  This also means they can have a problem functioning at high altitudes.  The other general complaint is that they add moisture to your environment.  Depending on the humidity where you are, this may or may not be an annoyance.  Lots of people like the radiant heat that they put out, and your cats may like it also.  I would guess the up close heat will keep them at a safe distance though.  That's just a guess, maybe someone here has real experience.  Most importantly, since they are catalytic, they convert the poisonous carbon monoxide to non poisonous carbon dioxide.  I personally though would not consider them safe to use without a carbon monoxide sensor since things don't always work like they are supposed to.
There is another version of that heater called the Platinum Cat. That one has a small vent fan to avoid some of the above issues, but it does require a tiny amount of electricity to function.  The Olympians do not.  We use a combination of heater sources: electric if adequate power is available, a standard RV furnace, an Olympian at times, and I have a Platinum Cat that I keep thinking I will install in the bedroom.  Too little oxygen or too much CO could ruin, or greatly prolong, a nights sleep.  It all depends on how you look at it.
Gary LaBombard
"Rustless Money Pit"
« Reply #21 on: October 31, 2010, 03:43:29 PM »
I will not shoot down the Edenpure product as I am sure because of many earlier models that were returned that they had to clean up their product quality from the past.  Because of this previous information from a few years ago I choose to get us a (Comfortzone Therapeutic Infrared Heater).  We purchased this two years ago, at that time there was two models, (CZ1000 or the CZ1500).  The 1000 model had 6 infrared heater cores in it which were smaller in diameter than the 1500 model.  The 1500 model only had 4 heater elements which were larger and just looked of quality that you would know was good.
Not to get into any contest of quality but research on the net, (Google)  and see that the Comfortzone Heater is assured to get 20,000 actual hours of use before a possibility of replacing any of the elements in the heater.  Versus the Edenpure's models expect 5,000 hours before needing coil replacement perhaps.
The replacement coils for the 1500 at the time we purchased ours was $15.00 each which we ordered as spares down the road, we hope way down the road.  That is quite cheap to us and I have to admit that this little bugger is great.  We close off bedrooms not needed to have complete heat in them to cut down the heated space for the heater to work keeping warm.  The comfort zone is also remote controlled is you want to use it or manual set controls as well.  We have an upstairs that the heat travels up the stairs freely because of heating rising of coarse and the upstairs is quite comfortable.
We have used our heater every day during the winter in SC, it may not get as cold as upstate NY but when it does dip down into the single or lower double digits it is still cold no matter where you live.  I sit in our home wearing a t-shirt and pants of coarse but we keep about 1000 sq. ft if not a little more really comfortable.  I might also add that all our furnature etc. is also kept warm as us from this heater and our puppies love that as well as us.  This helps with controlling the on and off of the heater if everything is as warm as we are, or I believe this anyhow.
We bought this with intention to use on our bus but you all know that isn't happening as yet!!!  So we use it in our home and even when we do get to use our bus we will either get another one for the house exactly or a newer model than the one we now have or move it from the bus to our home when needed.  It is not very heavy but is very good looking, we have the (Wood Grain Finish model) which goes with anything.
The motor is all metal roller bearings and the fan is so quiet you hardly can tell it is on but the comfort we receive says it is.  I have seen older Edenpure models that were really noisy when trying to watch TV or something and your heater is in that room.  Inquire if they have redesigned this feature as it is annoying to talk over, nap over and just a PIA to listen to.
Now things may have changed for Edenpure from when I mentioned the earlier models, research, find out how they are made, the size of the heater elements, life expectancy of the heater elements & the cost of replacements.  Note, order replacement elements no matter what you purchase now as in probably weeks they will be out stock because of design changes with the speed of technology now days.  This is only a suggestion.
Compare the differences of the heaters, perhaps all you do need is the $20 models from Lowe's etc!  But I can swear about the comfort we get with our Comfort Zone CZ1500, AC heater.
Also, don't shut your furnace completely off and depend only on your electric space heater as you will require heat in other parts of your home no matter what for safety of pipes etc.  You can cut down the amount of setting on your thermostat though and this will cut down the furnace use a lot more than you realize.
Don't take my word for it now, research as with this net we can all do now and then make a decision from your data you found.  We love ours.
Good Luck,
Gary
« Last Edit: October 31, 2010, 03:52:03 PM by Gary LaBombard » Logged
Gary
dougyes
« Reply #22 on: November 01, 2010, 06:19:30 PM »
I was surprised how well the Comfortzone heater worked. It was much better than the cheaper coil with fan type or the quartz radiant type of the same wattage. All theory aside as to why it shouldn't, that is my personal experience.
« Reply #23 on: November 03, 2010, 10:35:45 AM »
If a heater is shown in a full page magazine or newspaper ad you can be sure it is overpriced or worthless, or both.
You can either have electric heat that heats the air or heats directly at whatever is in front of it. No matter how you package it that is all it will do.
Of course it is cheaper to turn off whole house systems and only heat one room with a portable heater - makes sense.
We heat our 4104 with two 1500W portables ($19 at WM), usually on Medium which is about 900W. We seldom use both at the same time and almost never use high (1500W). Of course a 4104 is small but it is poorly insulated and drafty.
Any cheap elect heater will do the same, just be sure to get one with a thermostat, otherwise it runs all the time.
When without elect power we use two portable LP heaters at Med settings. They heat great but do cause condensation which clears up fast with the bus heat on.
« Reply #24 on: November 03, 2010, 12:32:37 PM »
I wandered over to the Henderson CW Undecided, I should have went straight to WM instead Shocked. Waste of time that trip was Angry. Maybe the end of the week then, Wally world bound...
« Reply #25 on: November 03, 2010, 03:19:44 PM »
I was at Costco today.  They had a couple of nice heaters.  There was a fan forced quartz one for $50. and another one with a remote for $40.
« Reply #26 on: November 03, 2010, 04:07:16 PM »
Just looked at this lil' fella at lowes, thows nice heat for a 1500W at $ 20.00 of course they were otta stock Grin
http://www.lowes.com/pd_42722-87513-DQ720_4294856722_4294937087_?productId=1182989&Ns=p_product_prd_lis_ord_nbr|0||p_product_quantity_sold|1&pl=1&currentURL=%2Fpl_Electric%2BFireplaces%2B_4294856722_4294937087_%3FNs%3Dp_product_prd_lis_ord_nbr|0||p_product_quantity_sold|1
 Smiley
« Reply #27 on: November 05, 2010, 07:12:04 PM »
I just noticed in an Eden Pure ad today that they heat the air at the  floor just as well as at the ceiling!
An amazing defeat of one of the laws of physics!
There is as much hot air coming from their ads as from their heaters.
