May 19, 2013, 12:48:02 PM *
Pages: 1 [2] 3 4   Go Down
Author Topic: Series 60 Bubbling Coolant  (Read 5738 times)
« Reply #15 on: November 20, 2010, 06:48:30 AM »
Wow, lots of simultaneous posting going on here!
You had to look very close to see the migration path of the combustion gases.  Indeed, the mechanic had to show me a couple of times before I could faintly see it.  Not obvious.
Head has not been tested, so it could still be the problem.
I will try to post a PDF of the page from the manual that shows the measuring of the liner height.  (Didn't work, so working on posting it elsewhere).
RichardEntrekin
« Reply #16 on: November 20, 2010, 06:52:18 AM »
Jim,
I have coolant in the oil. But no oil in coolant.
I don't know exactly where the breach is, but my thoughts are that whent the engine is running the compression in the cylinder is far greater than the compression in the cooling system, hence the exhaust gas pressurizes the coolant. When the engine stops, the coolant system is now pressurized and the engine is not, so the pressure forces the coolant into the cylinder. I just need to find the path.
I do not want to just throw parts at it, and cross my fingers that I fixed the problem. It's too much work just to hope I fixed it.
Richard Entrekin
95 Newell, Detroit S 60
Subaru Outback toad
Huntington WV
RichardEntrekin
« Reply #17 on: November 20, 2010, 06:53:18 AM »
I have the DD manual. I have to fab the sled for the dial indicator to fit on.
Richard Entrekin
Subaru Outback toad
Huntington WV
« Reply #18 on: November 20, 2010, 07:03:15 AM »
Wow, 25 steps later and I have a jpg that I can post and then you tell me you already have the info Grin
I probably need to step back and spend some time reading this thread again.  If you have water in the oil, that would explain the frothing on the rockers.
I will post the jpg for others.
Right now I am lost, and out of time.  I will take a look at the thread later today and see if anything trips some other thoughts.
« Reply #19 on: November 20, 2010, 07:24:03 AM »
Sounds like a cracked cylinder head-since no oil in the coolant.  If a cylinder liner was cracked, the coolant would be contaminated.  Cracked head allows oil and exhaust gases into the valve cover area where your fine mixture was made.  Sounds like it's new cylinder head time.  Good Luck, TomC
« Reply #20 on: November 20, 2010, 08:24:46 AM »
Head Gasket 5 to 6
Head 5 to 6
Deck 5 to 6
thomasinnv
Derrick Thomas
« Reply #21 on: November 20, 2010, 08:28:05 AM »
the one combustion chamber on the head shot sure looks clean, like it was getting steam cleaned, know what i mean?  a little rust next to the valve too.  sure looks like a leaky gasket or liner.  but what do I know, I'm just your average shade tree....
There are three kinds of people in this world....those that make things happen, those that watch things happen, and those that just wonder what the heck is happening. Which one are you?
1977 MCI Crusader MC-8
8V71N/740
Zeroclearance
« Reply #22 on: November 20, 2010, 10:38:37 AM »
From the pictures it looks like you have a liner that has "sunk"
« Reply #23 on: November 20, 2010, 10:47:28 AM »
Richard, are the head bolts the new style (white on top)
RichardEntrekin
« Reply #24 on: November 20, 2010, 10:49:01 AM »
Zeroclearance
What do you see in the pictures that tells you that you are looking at a sunken liner.
Richard Entrekin
Subaru Outback toad
Huntington WV
RichardEntrekin
« Reply #25 on: November 20, 2010, 10:51:26 AM »
Clifford,
They are not the new style. They are the original head bolts, and the engine has a a 1994 build date.
Richard Entrekin
Subaru Outback toad
Huntington WV
« Reply #26 on: November 20, 2010, 10:55:45 AM »
Richard, that is what I was thinking that looked like the old style head gasket upgrade to the new gasket and bolts and you will be fine I don't see a low liner in your photos
RichardEntrekin
« Reply #27 on: November 20, 2010, 10:57:41 AM »
This is a dumb newbie question that perhaps Clifford will humor me and answer. If the liner is sunken, is it as simple as replacing the liner? Does a new liner usually protrude the correct amount? or does a new liner automatically require recutting of the seat to achieve the correct height?
And where do you guys normally source your DD parts? Local shop? or favorite supplier?
Richard Entrekin
Subaru Outback toad
Huntington WV
« Reply #28 on: November 20, 2010, 11:18:24 AM »
Richard, if you do have one sunk they have to be machine out to accept the 0.30 over sized shim under the liner hope you don't have to go that route.    www.dieselpro.com is a good outlet for aftermarket parts I believe the head gasket set cost around 125 bucks I forgot what the new style head bolts cost somewhere around 5 bucks each
Lay a straight edge over the cylinders and use a feeler gauge at each cylinder you can tell real quick if one is low
« Last Edit: November 20, 2010, 11:25:04 AM by luvrbus » Logged
Zeroclearance
« Reply #29 on: November 20, 2010, 12:26:48 PM »
The lower liner looks a hair low.   This issue has plaggued the CAT 3406 "C" and "E" >>  erosion to the lower liner seal.
Most good shops will have the tool to cut the upper cylinder block liner seat.    Clifford has mentioned the correct method to restore the height with a shim.
Get a good straight edge and a good depth "micrometer"   You can use a feeler gauge to measure around the liner to check your height.   This is a good practice on any engine with the cylinder head removed.
« Last Edit: November 20, 2010, 12:28:37 PM by Zeroclearance » Logged
Pages: 1 [2] 3 4   Go Up
