June 19, 2013, 12:21:24 AM *
Author Topic: ID tank material PLS  (Read 1075 times)
wrench
« on: December 05, 2010, 09:11:00 AM »
 Any one can ID this black tank material, I got a hot air welding gun & want to try to weld a crack in it.
 [URL=http://img200.imageshack.us/img200/1440/holdingtank.jpg    (larger size)
 Any one can help?    thank    wrench
« Last Edit: December 05, 2010, 11:04:49 AM by wrench » Logged
Slow Rider
« Reply #1 on: December 09, 2010, 09:43:37 AM »
Bump
Yes I am a BUSNUT
1976 MCI MC8
« Reply #2 on: December 09, 2010, 10:01:09 AM »
I'm not an expert on plastics but I would guess that if it is black, then it is ABS.
wrench
« Reply #3 on: December 10, 2010, 03:48:57 AM »
  It's the black water tank, but the color is gray /blue.  Test show that it melt at low temp, lower then the 3 type plastic welding rod that I got. HuhHuhHuh??
       thank   wrench
« Reply #4 on: December 10, 2010, 05:00:26 AM »
is the fitting in picture of same material? if so take a saw and trim a 1/8 inch cut off top and use for welding rod. Or try something like JB Weld or epoxy. Is crack where you can apply mechanical patch?
« Reply #5 on: December 10, 2010, 06:12:00 AM »
A friend in NC bought an plastic welder that uses hot air. The manual that came with it  had a chart showing the different symbols used on plastics to identify them. Are there any identifying symbols on the tank?  (I think they would be similar to the symbols on plastic bottles or plastic body parts on automobiles).  Jack
rgrauto
« Reply #6 on: December 10, 2010, 06:20:47 AM »
I repaired a holding tank with an old soldering iron(large elect.) and zip-ties ,fuse it together like welding. 10yrs and still holding.  Gen
wrench
« Reply #7 on: December 11, 2010, 10:43:10 AM »
  Thankss guys,   I melt the edge with soldering gun to close the crack & then filled & built up with expoxy, will see what developppe.   The fitting are different material, they're glue on & it's not spinned.
        wrench
« Reply #8 on: December 11, 2010, 04:51:41 PM »
and the zip ties come in all colors too Wink
