February 19, 2018, 07:52:38 PM *
Pages: 1 2 [3]  All   Go Down
Author Topic: lost my nuts  (Read 5671 times)
« Reply #30 on: December 13, 2010, 05:32:34 PM »
Quote from: Chopper Scott
Easy way around that is to put those studs in the freezer overnight and hang a trouble light on the hub. I do that even when I'm pressing stuff together.
Scott I know exactly what you mean! We do the same thing around here with more than just studs!
« Reply #31 on: December 13, 2010, 05:35:54 PM »
Dry ice in a cooler, common practice. fwiw Smiley
« Reply #32 on: December 13, 2010, 05:41:50 PM »
Quote from: van
Yeah but it can be hard to come by in Podunk USA and has to be used right away.
For those of us that have garage beverage fridges it's cheaper and easier to throw the parts in the freezer overnight.
B'sides mine always gets wet and greats a huge fog! Wink
David Anderson
« Reply #33 on: December 16, 2010, 09:46:59 AM »
As per Clifford's suggestion I finally had some time to look at the wheels.  On the rim it says:
Alcoa  7200lbs max  120psi T-DOT
0994 Part #983100   24.5x8.25  15degree DC
The nuts I'm using are:  EUC E5977L  outer cap nut.
Anyone know from this if I have the correct combination??
David
« Reply #34 on: December 16, 2010, 10:35:04 AM »
According to this web site https://www.fleetwheel.com/store/page8.html (on page one) it says Budd stud piloted wheels all use 1.5" non-flange ball seat nuts.  So it that's what you have you should be good.
« Reply #35 on: December 16, 2010, 10:42:42 AM »
David, that is a aftermarket nut made by Euclid checkout the Dorman site it will  have a cross reference chart with the bevels
Pages: 1 2 [3]  All   Go Up
