May 24, 2018, 08:24:06 PM *
Author Topic: Sheppard PS and Allison V730  (Read 8991 times)
Paso One
« Reply #15 on: December 16, 2010, 01:23:27 PM »
My Stone Bennett shifter is all electric.
I pulled out my manual that came with the Stone Bennett shifter.  The instructions included were with the optional hydraulic electric solenoid as opposed to the air/ over electric solenoid.
Closer examination of mine is the solenoids are part # BS30428 which are the coil-air solenoid.
The manual says "Neutral off module prohibits voluntary shut-down of coach when transmission is in gear".
next sentance says  "pressuriized gas accumalator provides shifting power to return to neutral in the event of an involuntary engine shut down "
1996 MCI 102 D3
gmbusguy1
« Reply #16 on: December 16, 2010, 01:51:20 PM »
I believe your fishy has a VS model transmission if so the shifter is a whole different animal than the V730 or h series
Brian, I am not 100 sure but believe that the MCI uses a different model Shepperd gear box than a Buffalo
the GM pitman arm zero point is different than a MCI
Chris
« Reply #17 on: December 16, 2010, 01:57:59 PM »
Chris, you are no doubt right on that, but I suspect that the centering requirement remains.  I was astounded at the effect it had when I fixed mine.
gmbusguy1
« Reply #18 on: December 16, 2010, 02:06:04 PM »
Brian Yes you are correct in that the important thing is the spec, I just did not want anybody to make adjustments with out reading the manual for their specific bus
thanks
Chris
Paso One
« Reply #19 on: December 16, 2010, 02:08:50 PM »
No Chris  My transmission is the V730   I took out the VH 9  that it originally had. ( see  pdf attachment)
I also have a VS transmission on the shop floor out of Fishbowl Brians  Seattle  Bus,  I can visually see the differance. :0
1996 MCI 102 D3
johns4104
« Reply #20 on: December 16, 2010, 02:29:12 PM »
Chris,
My 4104  caster was 1.5 deg. positive, I changed it to 3 Degrees by adding tapered shims. It helped alot on the highway.
I thought about adding more positive caster, but thought it would increase the steering effort too much in town.
It has the manual box.
I am running 11R22.5 radial tires.
I have maybe 2" slop at the wheel.
PD4104-1859
In Sunny Arizona
Apache Junction Near Phoenix
gmbusguy1
« Reply #21 on: December 16, 2010, 04:08:17 PM »
John, I would probably leave that 3 degrees alone with manual steering. the only handling issue usually associated with too much caster is after turning a corner the steering wheel will not return to center as well.
where did you shim the 4104 for the caster adjustment???
Chris
« Reply #22 on: December 16, 2010, 08:22:25 PM »
Thanks for all the good info, keep it coming. When the weather gets more agreeable I'll start digging into this.
Yes, it has the original large steering wheel, didn't think about that. Every time I come to a slow sharp turn I reach around the wheel for a strong pull and it isn't there, will take a bit of time to get used to that but it is great.
OK, I know what goes on at Jack's but I still don't know where it is??
johns4104
« Reply #23 on: December 16, 2010, 08:34:33 PM »
Chris,
I thought that more caster would increase the effort at the wheel.
I added the shims below the axle where it bolts up at.
PD4104-1859
In Sunny Arizona
« Reply #24 on: December 16, 2010, 10:51:01 PM »
Gus -
Jack's party (Bussin' 11), takes place in Arcadia, FL, over New Year's Weekend. (12/29 > 01/02)  Specifically at the Turner Agri-Center in Arcadia, 90 miles SW of Orlando, or 90 miles SE of Tampa.
Since it's the 10th anniversary, there will probably be well over 100 buses of all shapes, makes and sizes in attendance.
Well worth the trip and there's room for one more - come join us!
« Reply #25 on: December 17, 2010, 04:27:11 PM »
RJ,
Thanks, Florida has never been on our itinerary. That is a long haul from Fresno! Do you really go from CA to FL during the winter??
 I never did get a chance to stop by to see you during our annual trips from Tucson and SD up to WA, there was always something making me rush up the state.
One day!!
johns4104
« Reply #26 on: December 17, 2010, 06:08:20 PM »
Gus,
There is always the bus rally in Quartzite az.
PD4104-1859
In Sunny Arizona
« Reply #27 on: December 17, 2010, 08:21:50 PM »
Gus -
For Jack's rally, this year it's USAir, Enterprise RAC & Holiday Inn Express.
Well worth the $$, IMHO.
Will probably make the drive down to Quartzsite in January, too.
