May 22, 2018, 09:09:08 AM *
Author Topic: air tank drain valves  (Read 1615 times)
thomasinnv
Derrick Thomas
« on: December 20, 2010, 07:11:28 PM »
I would like to replace the drain valves on my air tanks with the ones you can attach a cable to and pull from the wheel well.  Too much of a pain having to get under the bus every so often just to drain the tanks.  Any suggestions on where to get them?  Any part numbers?
1998 MCI 102-DL3
Series 60 11.1/Alison B500
« Reply #1 on: December 20, 2010, 07:14:42 PM »
Derrick, Ryder Truck Parts or Eastern Marine where are you at now you can order through Napa
thomasinnv
Derrick Thomas
« Reply #2 on: December 20, 2010, 07:17:35 PM »
Clifford, I am back in Bouse for Christmas with the family then off to Phoenix for a week over new years.  I will check Napa online.  Thanks!
1998 MCI 102-DL3
« Reply #3 on: December 20, 2010, 07:38:51 PM »
Derrick, RyderParts have the drains on sale for 8.22 each with the cable Midland/Haldex number 12104
« Last Edit: December 20, 2010, 07:44:21 PM by luvrbus » Logged
thomasinnv
Derrick Thomas
« Reply #4 on: December 20, 2010, 07:47:58 PM »
Ok I'll check that out, thanks Clifford!
1998 MCI 102-DL3
« Reply #5 on: December 20, 2010, 07:52:51 PM »
NAPA has that part listed online for $8.99.  Ryder usually blows away NAPA prices, but not really in this case.  I have seen Ryder prices that were half of what NAPA wanted and NAPA claimed their cost was more than Ryder was selling for.
If NAPA has a warehouse locally they can probably get the part same or next day.  These valves are available with different length cables.  I got mine from NAPA.
« Reply #6 on: December 20, 2010, 07:58:25 PM »
The difference is you are buying a Midland/Haldex double seat better drain than a Napa sells
« Reply #7 on: December 20, 2010, 07:59:53 PM »
It is the same part number from Midland.  Does Midland sell something different to NAPA than they do to Ryder?
« Reply #8 on: December 20, 2010, 08:10:42 PM »
If Napa is selling Midland now go for it but everyone I bought from Napa was a Velvac same as their relays hasn't been that long ago the one I have in the shop from Napa is a Velvac single seal but I don't care one way or the other I was just trying to help a friend find the valves
« Last Edit: December 20, 2010, 08:17:23 PM by luvrbus » Logged
« Reply #9 on: December 21, 2010, 09:11:31 AM »
NAPA will sell whatever you ask for.  They may not have it in stock, but they have most of it at the warehouse.  Sometimes I ask for a really oddball part and they don't have in the local warehouse and they would charge for shipping if it is in Indianapolis or something.
You might not get a Midland if you just ask for an air tank drain valve.  Now, if you ask for a 12104 they'll get you the Midland part.  At my local NAPA they would look at me funny if I asked for an air tank drain valve.  They would have no clue.  I usually look up the part number on NAPA Online and then call them to order the part.
