May 19, 2013, 11:39:40 AM *
Author Topic: new to the bus world  (Read 4051 times)
« Reply #15 on: December 22, 2010, 01:33:54 PM »
After being covered in grease and goo I use cheer or tide to help cut the tough stuff then hand cleaner also put hand lotion on before helps release some of the bad stuff..keep a pair of clothes dedicated to these voyages into the belly of the beast.. If local guy is expensive on started overhaul:ask here someone might have extra.  Bob
« Reply #16 on: December 22, 2010, 01:39:31 PM »
Probably don't want to hear this now....... But said 3 starter bolts that were finger loose and being able to move the starter with said pry bar could be the only problem you have!
Loose starter = bad ground...... bad ground = no start!
If it were me the first thing I'd try is tightening the starter and try it.
FWIW Grin  BK  Grin
« Reply #17 on: December 22, 2010, 01:41:52 PM »
Don't forget typical GM starters are "reverse" rotation from normal, since the engine is reverse rotation (no I don't remember if it's clockwise or counter clockwise and I am too lazy to look it up).  But a truck store starter for an 8V71 probably won't work.
1980 MCI MC-5C converted
Vintage race cars -
1978 Lola T440 Formula Ford
1972 NTM MK-4 B/SR
« Reply #18 on: December 22, 2010, 01:52:35 PM »
good catch BK !
busenthusiast
« Reply #19 on: December 22, 2010, 02:19:56 PM »
Busted Knuckle...........YOU ARE THE MAN!!!!!....I took a quick break before getting to that last bolt and read your reply....quickly decided to give it a try since I really wasn't that far into the process and bada bing......we have ignition......thank you so much.....
« Reply #20 on: December 22, 2010, 03:57:53 PM »
No problem Billy been there done that, got the T-shirt to prove it! Wink
busenthusiast
« Reply #21 on: December 22, 2010, 04:01:28 PM »
Now I just need to get to the bottom of this smoke issue.....should I start another post?
« Reply #22 on: December 22, 2010, 04:03:43 PM »
That would be a good idea. That way it's easier to find when searching. Also be descriptive in your title, engine, problem etc.
Glad you are moving onto bigger and better things! Wink
rampeyboy
1954 Scenicruiser PD4501-227
« Reply #23 on: December 22, 2010, 04:58:49 PM »
Welcome to the club. I too am in Columbia. I doubt I will be of much help with your bus, as I am struggling a little with my Scenicruiser project (mostly lack of time at the moment). If you ever want to talk busses give me a call. 803 319 0585
Boyce
Boyce Rampey
Columbia, SC
Scenicruiser 227
busenthusiast
« Reply #24 on: December 22, 2010, 05:19:25 PM »
Cool....a local bus owner. I'll definitely keep your number on hand Boyce. You can reach me @ eight zero three nine nine seven zero two five one......
rampeyboy
« Reply #25 on: December 23, 2010, 03:18:10 AM »
I forgot, there's a 4106 owner here too. I don't recall seeing on this board, but I think he's on the yahoo gmc busnut group. If memory serves his last name is Roberts? or McRoberts? I forget. Anyway, he keeps it in West Columbia. I emailed back and forth a few times with him years ago, seems like a nice guy. I'll be at a funeral today, then the next couple days will be busy with Christmas stuff, but maybe we can chat next week sometime.
Boyce
Boyce Rampey
Columbia, SC
Scenicruiser 227
Timkar
« Reply #26 on: December 23, 2010, 09:59:24 AM »
Don't know if you are still looking for info on shifting, but here is link to an excellent article on BNO board..
http://www.busnut.com/bbs/messages/12262/16204.html?1167073154
65 Eagle 01  102"/45'
S60 HT754
Cawston, British Columbia
« Reply #27 on: December 23, 2010, 10:10:11 AM »
Now the starter motor on my bus has a separate ground cable to a dedicated ground lug on the chassis - that may be something to think about rather than relying on the ground through the engine block.  Not possible to have too good a ground connection!   Wink
Vintage race cars -
1972 NTM MK-4 B/SR
busenthusiast
« Reply #28 on: January 04, 2011, 05:53:38 PM »
Looks like my loose starter was just a pipe dream after all. Tried to spin my engine this afternoon to check the idle speed and the starter quit working again. I decided to pull it and it looks like the only issue is the starter solenoid and not the starter itself. Anybody know if a solenoid can be purchased separate?
James77MCI8
« Reply #29 on: January 04, 2011, 07:00:41 PM »
Solenoids can be purchased separately. If I had the starter off I would take it to a local starter/alternator shop and have the unit rebuilt. I am in Spartanburg 864-923-5957.
77 MCI 8
8V-71 4 spd
