January 22, 2018, 12:04:30 PM *
Author Topic: Should I use marine 3 wire cable or seperate wires for 110V AC?  (Read 6235 times)
« on: September 04, 2006, 06:49:50 PM »
I need to order more wire for my bus.  Any reasons not to use the three wire marine cable (like romex) for 110V AC instead of three seperate wires in a conduit?
I really need to save time to get my conversion usable in three weeks and the romex would be faster.  It would also make life easier as the cable is more flexible than conduit.
Brian Elfert
« Reply #1 on: September 04, 2006, 07:02:15 PM »
Brian I would think you could use the marine wire IF it's stranded. IF it's solid LIKE ROMEX, then I would think it wouldn't be real safe! Now I am the first to admit, I'm not an authority on this but from what I've learned from coming here and from friends like Jack Conrad this is all I can offer. Order the wire that is right and you'll be money ahead, though not done as quick as you want!
« Reply #2 on: September 04, 2006, 07:47:28 PM »
The marine 3 wire cable is stranded and tinned like the regular marine wire.
Brian Elfert
« Reply #3 on: September 04, 2006, 08:01:56 PM »
Brian, again not being an authority on the subject but your description tells me that yes it will be just fine!
Others may have a btter opinion!
« Reply #4 on: September 05, 2006, 04:54:33 AM »
Brian,
    I use individual wires in the plastic flexible conduit, but that is just "my way". I have heard that the marine cable is not UL approved, but it is probably as good as or better than the UL approved "romex".  There is always a discussion about insurance not paying if you have a fire because you used marine (non UL approved) cable. The conduit does offer a little more protection for the wire, but either should work.  Jack
« Reply #5 on: September 05, 2006, 05:19:19 AM »
Brian,
Most marine wire wire seems to be UL listed these days.  Waytek's marine wire is under UL 1426.  The stuff I bought from Skycraft Surplus has a UL listing sticker on it, but doesn't list the UL number.
I've never heard of a insurer not paying for a fire unless it was arson.  They will probably drop your insurance if it was something stupid.
Brian Elfert
4104bigred
« Reply #6 on: September 05, 2006, 06:04:52 AM »
Brian  we just searched for marine cable for our 04 and this company had the best price by far on the stuff and fast easy shipping
heres a link go to the specials page
http://www.terminalsupplyco.com/default.asp
chris
« Reply #7 on: September 05, 2006, 11:39:30 AM »
Damn, I read this about five minutes after I had ordered my cable from Skycraft Surplus earlier this morning.  I could have saved about $30.
Brian Elfert
Jerry Liebler
« Reply #8 on: September 05, 2006, 04:29:10 PM »
Brian,
     This question has been discussed many times before.  And generated considerable controversy. To summarise:  The marine cable is NOT approved, under the National Electrical Code (NEC), for use in an RV.  While it may in fact be more suitable it is NOT approved.  Solid wire 'romex' is approved as is stranded 'thnn' in conduit.  The choice is up to you.  I chose to use the plastic flex conduit and thnn for most of my wiring but I have  a few pieces of romex running up walls were I wanted the 1/4" thickness.  Regardless of which you chose be sure to use the proper termination technique.  It is unaceptable and unsafe to simply wrap stranded wire around a screw and tighten the screw (at an outlet or switch).  If you use stranded wire you'll need to crimp terminals on for these kinds of connections.
Regards
Jerry 4107 1120
« Reply #9 on: September 05, 2006, 04:48:47 PM »
Jerry, all of my wiring is stranded and all of it is wrapped around the terminal screws at all outlets and switches! Is this wrong?
« Reply #10 on: September 05, 2006, 05:09:53 PM »
Oh Geez....
Where's my flack jacket and helmet?Huh
here we go....
Jerry Liebler
« Reply #11 on: September 05, 2006, 05:26:27 PM »
Ace,
     Yes it's wrong and it's unsafe to wrap stranded wire around a terminal screw.  The problem is the connection will not stay 'tight' under the least bit of temperature cycling which may be due to heating caused by current flow.  Once the connection is loose it can easily start a fire.  Please invest in a good crimper and a couple boxes of crimp on terminals and re do all those connections.   An electrical fire due to this 'mistake'  would be far more expensive.
Regards
Jerry 4107 1120
« Reply #12 on: September 05, 2006, 05:54:27 PM »
I used romex for most 110VAC.  It makes a nice connection at the terminals.   If romex is anchored well, I'll be dead (not due to electrical fire) before the stuff "work" hardens and cracks in a bus chassis.   Heat pumps are wired with 12g  MC..which is stranded.   All outlets are wired with romex.  All 12VDC is stranded.  And, the inverter feeds and returns to the sub panel are stranded.
I'll be the first to post any issues I have with romex.   Some folk will cheat after growing tired of running miles of stranded cable bundling 3 leads with every run...make that "home run."   Confusion may create some odd wiring outcomes.
Stranded wire on some 110VAC components requires a ton of work to make fast.  As long as your wiring is properly anchored, and run in something to prevent chaffing, the circuits are not overloaded, and all circuits are properly fused...fire from wiring is unlikely.   One thing about romex, is that it will always have a good bond, and neutral.
Another thing is before you spend tons of time and money on stranded wire, check out some of the expensive motorhomes and see what was used to wire the 110VAC circuits
After spending too many years in the marine business...I found that stranded boat style wiring has its issues too.
Please be advised that due to my use of romex, no offense will be taken if ya'll that have romex free coaches wish to park like....a few feet further from my coach.   I like a large open campsite!  Wink
my dos centavos!
JR
« Reply #13 on: September 05, 2006, 06:22:48 PM »
Well now, I wonder if I can a refund on my rally fees from Timmonsville and Arcadia? I don't think anyone would pit next to me knowing how unsafe my coach is and I know I don't have near enough time to change it out by then which by the way is one month from today!
Oh well, if not, money well spent! Welcome to bussing! Smiley
« Reply #14 on: September 05, 2006, 06:46:38 PM »
Nope.  No refunds.  You just gotta be there.  We pays our money and we takes our chances!
I'll park next to you...no problem.   My bus will bring...."flavor" to the neighborhood... Roll Eyes
See ya, JR
