February 24, 2018, 04:14:28 PM *
Pages: 1 2 [3]  All   Go Down
Author Topic: Single rear axle MCI  (Read 10912 times)
« Reply #30 on: January 14, 2011, 01:26:10 PM »
     The v-drive in the 4106 limits you to the v730, which is a 3 speed(won't fit in the 4104).
        "never say never".
uncle ned
It just depends on the size of your hammer or checkbook.
wildbob24
« Reply #31 on: January 14, 2011, 01:37:51 PM »
I agree. It's certainly possible, if you change the engine and rear axle, to make the v730 fit in your 4104.
Bob
P8M4905A-1308, 8V71 w/V730
Custom Coach Conversion
Greenville, GA
« Reply #32 on: January 14, 2011, 08:06:21 PM »
WildBob -
Uncle Ned has a 6V92T bolted to a V-730 shoehorned into the engine compartment of his 4104 - a common swap, btw.
Don't remember if he said he used a 4106 or later rear axle, or if he flopped the 4104's and re-indexed the pumpkin.
But it works - sounds sweet, too!
wildbob24
« Reply #33 on: January 14, 2011, 08:12:35 PM »
RJ,
Yes, I remembered reading that somewhere, hence my reference to changing the engine and axle. When I worked for Ray Cox at Coach Services in Atlanta, we had a customer with that same conversion. It was done using a 4106 axle.
My earlier reply to Art was in reference to using a V730 in a 4104 with the original engine and axle. Won't fit.
Bob
Greenville, GA
blank
« Reply #34 on: January 14, 2011, 10:19:34 PM »
Hmmmmmmm. Sounds intersting
Pages: 1 2 [3]  All   Go Up
