May 23, 2013, 01:31:54 PM *
Author Topic: Gear Set  (Read 817 times)
06 Bill
« on: January 13, 2011, 08:57:42 AM »
Need help to identify gear set.  33 teeth  Has # 2229123 stamped on it.
Ring gear 12 - 1/2 bolts  on 10 1/4" bolt circle. Carrier bore of 9 1/4" with square acme type teeth around inside.
Pinion gear 8 teeth  12 1/8 long overall. Gear face to yoke end 7 1/2".     4 1/8 ratio or 4.125-1
pvcces
« Reply #1 on: January 13, 2011, 08:47:48 PM »
The ratio is identical to the 4106.
Maybe someone else can help you with identifying the model of bus it fits.
Tom Caffrey
Tom Caffrey PD4106-2576
Suncatcher
Ketchikan, Alaska
