January 16, 2018, 03:50:34 AM *
Author Topic: Are cast valve covers better than stamped valve covers?  (Read 2622 times)
Barn Owl
Roanoke, VA
PD4106-1063 "Wheezy Bus"
« on: September 08, 2006, 08:12:31 PM »
I can get my hands on a set of cast valve covers (free) and I wanted to know if they were better than stamped steel for some reason, other than just aesthetics. Possibly they don't leak as much?
akbusguy2000
« Reply #1 on: September 08, 2006, 08:36:50 PM »
If you are referring to valve covers for an 8V71, I believe the cast ones are different.  They are taller to provide space for the jake brakes.
tg
Barn Owl
Roanoke, VA
« Reply #2 on: September 08, 2006, 10:38:09 PM »
So I could eliminate the spacers?
ChuckMC8
« Reply #3 on: September 09, 2006, 02:25:38 AM »
Laryn, In aluminum, there is a standard cover and then one that's taller for the Jake installation. Or.....use the standard with a spacer.   (I think this is right) chuck
« Reply #4 on: September 09, 2006, 05:22:58 AM »
As mentioned, there are 2 different cast valve covers. I think the cast covers are less likely to leak because the stamped covers can be warped by overtightening. If you have a GM with a OEM tailgate, the taller (Jake Brake) cover will not allow the tailgate to close without altering the door.  Jack
