May 23, 2013, 02:50:40 PM *
Author Topic: Wiring (installation) Info for Onan Marquis 7000  (Read 4662 times)
oldmansax
Tom & Phyllis
'82 Bluebird Wanderlodge PT40
« on: September 10, 2006, 04:47:38 PM »
Anyone have a link to an installation or wiring  diagram for an Onan Marquis 7000? It appears the generator was upgraded in my bus at some point but it is still wired to a 20 amp panel. I need to change that but I can't do it without a wiring diagram (nothing is marked). Thanks!
'82 BlueBird WanderLodge PT40 being rebuilt
Delaware
DON'T STEAL! The government hates competition!
TomCat
It's 4:20 somewhere...
« Reply #1 on: September 10, 2006, 05:33:22 PM »
On my Onan Marquis 5500 LP it is as follows
Black = Hot
White = Neutral
Green = Ground
Jay
87 SaftLiner
« Last Edit: September 10, 2006, 09:39:40 PM by TomCat » Logged
Nick Badame Refrig. Co.
« Reply #2 on: September 10, 2006, 05:59:54 PM »
Hello Oldmansax,
Here is the Onan direct link to the Marquis 7000
http://www.onan.com/onan/rvgenerators/Marquis/generatorProductDetail.jsp?prdid=prod90017
Hope this helps
Nick Badame
oldmansax
Tom & Phyllis
« Reply #3 on: September 10, 2006, 07:25:56 PM »
I have not followed this up very far yet, I am still looking thru the documentation that came with the bus. Jay, my junction box has 4 wires, all of which have been painted over. I will find out the original colors when I get into the box. Nick, I looked at Onan's site before but they just have ads, no diagrams that I can find. All generators I have had dealings with before have either three wires (110 leg, 110 leg, neutral leg, & use the frame for ground) or four wires ( 110 leg, 110 leg, neutral leg, ground leg) unless it was a 3 phase generator which is not applicable here. Do some RV generators produce only 110 volts? In this case, that would mean a 7000 watt unit would produce 110 volts @ 63 amps? The wires on my generator do not appear to be large enough to carry that kind of amperage. Huh
Delaware
TomCat
« Reply #4 on: September 10, 2006, 09:33:57 PM »
Oops, of course you're right, there should be 4 wires for that type genny. I have since pulled out my Onan book and here is what it says...
L1 Black
L2 Black (Should have stripe)
N White
G Green
Jay
87 SaftLiner
oldmansax
Tom & Phyllis
« Reply #5 on: September 11, 2006, 04:50:57 AM »
Thanks Jay! Smiley Now all I have to do is find, purchase, and install new panel, remove all old wiring, reroute what's left to the new panel, re-wire generator and shore power lines.........HMMMMMM, this aint gonna happen today
Delaware
