May 23, 2018, 06:13:04 AM *
Pages: 1 2 [3]  All   Go Down
Author Topic: Tire pressure monitoring system purchase advice?  (Read 9280 times)
« Reply #30 on: June 25, 2011, 07:17:08 AM »
Jim has a good point. Whenever we stop, I check the tires with my hand.
Now, I will say there are days when it is very hot, and I feel the tires. Then they might be a tad warmer then I can handle....
technomadia
Zephyr - 1961 GM PD-4106-446
« Reply #31 on: June 25, 2011, 11:39:07 AM »
It appears as if the Pressure Pro sensors actually transmit temperature data as well, though with very coarse accuracy:
http://www.advantagepressurepro.com/images/Temperature_Measurement.pdf
They also seem to offer ways to get at the raw data stream from the monitor via RS-232, potentially useful for future geek projects.  Neat.
   - Chris
« Reply #32 on: June 25, 2011, 03:22:23 PM »
Since my last post I turned on the Hopkins monitor again and it is wrong on every tire. Two are reading low by 14 psi and two are reading high by about the same amount?? Two are not reading at all!
It could be because I'm parked near two metal buildings, had that problem before but I'm going to call their tech support again.
If I can't get this corrected Jim may be hearing from me because I'm not going to be without them again.
thomasinnv
Derrick Thomas
« Reply #33 on: June 25, 2011, 07:25:52 PM »
check these guys out too, they've been around a little while and have good prices.
http://www.tsttruck.com/
1998 MCI 102-DL3
Series 60 11.1/Alison B500
Pages: 1 2 [3]  All   Go Up
