May 23, 2013, 10:03:45 AM *
Pages: 1 2 [3]   Go Down
Author Topic: Stuck for the first time  (Read 3891 times)
« Reply #30 on: February 13, 2011, 07:08:41 AM »
fwiw this can be done by a decent tire jockey with the wheel still on the bus, but the inner run up on a block.  A big sledge and some tire irons to get it off the bead.  If you want a workout try it yourself!
wal1809
« Reply #31 on: February 13, 2011, 08:40:10 PM »
Hello Zub,  I believe I will leave it to the experts and just hang around a while.  Believe it or not the first job I had out of TSTI (Diesel mechanic school) was working in Austin as a street sweeper mechanic.  That translates into-the sweepers were always getting flats.  To the tune of about 4 a night.  I had the mechanic truck and when they got a flat you could bet it was going to be the inside tire.  While I fired up the compressor the workers would get under the truck and jack it up.  About he time they were getting it high enough I had that 1 inch impact wrench going at it.  The workers were then getting a good tire off my truck as I slammed it back on with the impact wrench.  They would take off and I would stay behind fixing that tire.  We used split ring and tubes.  I would patch the tube and put it back it and air it up.  Load it on the truck and catch up with the sweepers just in time to, you got it, fix another tire.
www.snakebreaker.com
Iceni John
« Reply #32 on: February 13, 2011, 09:32:48 PM »
BK, what's the difference between regular Schrader cores and cores for tires like ours?   I have plenty of cores from Schrader bicycle tubes (bike tires can sometimes exceed bus/truck tires' pressures) which work for 100-plus PSI without a problem.   Should I buy something different, or will these work OK as replacements?   I always keep a few cores and a CalVan 4-way tool in my car "just in case".
Thanks, John
« Last Edit: February 13, 2011, 09:35:39 PM by Iceni John » Logged
Iceni John
« Reply #33 on: February 13, 2011, 09:33:34 PM »
Oops, sorry, double posted.
« Reply #34 on: February 14, 2011, 06:54:29 AM »
Thanks, John
John,
I honestly don't know the difference between the 2. Could be a tougher spring, better quality material, different type of seal. Really I just don't know.
But I do know two things.
#1) I have had valve core problems in the past and just used "what I had laying around" and had repeat problems.
And then one day @ the tire shop I said something about having quite a few core problems lately and the owner went in the shop and grabbed a box (1/2 empty w/top 1/2 tore off) of cores and gave them to me. And said "here do yourself a favor and REPLACE all cores on ANY tires that we haven't serviced for you! These are heavy duty cores and it's all we use!"
#2) I learned that if you tell a FNG he didn't read the post right he will go off on you and proceed to tell you how much more "world experience he has than everyone else on this board!"  (and can't even get my name right! IT'S BK not BN DICK!)
Iceni John
« Reply #35 on: February 14, 2011, 07:38:55 AM »
BK,
Thanks for your advice.   I'll ask ABC Bus for some good ones.
Barn Owl
Roanoke, VA
PD4106-1063 "Wheezy Bus"
« Reply #36 on: February 14, 2011, 12:53:56 PM »
BK got his first kill and didn't even mean to. Some have all the luck! I tried on several and they just dug their heels in and became valued contributors on the BCM board.
Dick, I can see how not knowing how BK works might have given the impression of a slap even though the intention wasn't to do that. Our numbers are to small to have someone chased off, and we want you to feel welcomed and valued. Keep posting and glad to have you here.
Nellie Wilson
« Reply #37 on: February 15, 2011, 02:42:52 AM »
Geez, BN,  Roll Eyes why must you sugarcoat everything?  Wink
Hey, how'd you guys know this "FNG" is named "DICK." I don't see any name in his profile (or am I missing stuff too?).
Sorry, back to the topic: As mentioned (near beginning of thread), my outside rear went nearly flat. Started to inflate but it leaked from the valve. I twisted the core (with one of those little core tools) and the leak stopped. Then I re-filled the tire. Been quite awhile and it's holding air just fine.
Trouble is, I didn't squirt to determine exactly where it was leaking. My Dumb! So now that it's not leaking, how do I find the 'leak'? Or am I worried for nothing? (Wouldn't be the first time... I'm so paranoid about any little thing that goes wrong...)
Hey, Dick (or whatever?), c'mon back. I'm the biggest screw-up you can imagine... and most of these guys even talk to me. Shocked  As someone said, it's a flat medium and tongue-in-cheek Tongue comments (and such) are hard to discern. Plus BN is notoriously picky about his name. Grin
Nellie
wal1809
« Reply #38 on: February 15, 2011, 05:37:33 AM »
Hello Nellie,  It sounds to me like you found the leak.  THe valve core just needed to be tightened.
Oh and how come you don't have your bus info in the sig so we know what kind of bus your driving.
« Reply #39 on: February 15, 2011, 09:48:15 AM »
I am new to buses, I am NOT new to mechanics. I was earning a living as a professional mechanic before BN was born. I spent most of my Navy time as a trouble shooter,electrical and mechanical, in a rating that is basically automotive. I have worked on more kinds of autos both foreign and domestic than many of you have even heard of, if you want the list I can probably come up with one. Many without manuals or any kind of book at all. I have been crew chief on both IMSA and SCCA race cars.
I joined this forum because I like to do a lot of research on anything I undertake, and to get ideas, I also thought that I might be able to add something once in a while.
BN is probably a very nice guy, I have no idea, and wouldn't be able to tell from the above exchange.
Dick
Nellie,
The above direct quote is where I got his name was Dick. (honestly I would not just call him one without a reason Wink)
And your one of the few that I'll allow to change my name knowingly!
wal1809
« Reply #40 on: February 15, 2011, 09:50:20 AM »
« Reply #41 on: February 15, 2011, 11:30:59 AM »
BK,
Well said and long over due.
You have more patience than I and that, of course, is a good thing.
Nellie Wilson
« Reply #42 on: February 15, 2011, 11:51:49 AM »
BK -
Just as suspected, I missed the obvious (again).
As to your follow-up comments,  Roll Eyes and  Wink respectively.
Wal - That makes me feel better; I'd hate to pull a wheel only to confirm nothing's wrong ('course I'd rather be safe than sorry, too). As for the missing info, my oversight. I'll get that done.
Thanks to both.
Nellie
Pages: 1 2 [3]   Go Up
