April 21, 2018, 06:22:27 PM *
Author Topic: Dash lights/Tail lights out  (Read 1889 times)
thejumpsuitman
« on: February 13, 2011, 05:08:17 AM »
Good morning.  Got a little problem.  Dash lights and tail lights are out on an Eagle 05.  Any ideas?  I'm thinking ground, but have no wiring diagrams to hunt it down.  I know in a car, the tail lights are dash lights are always on the same circuit.  Thought it might be a similar thing.  Thanks.
Marc
1986 Blue Bird Wanderlodge PT-40
DD 8V92TA, Allison HT748
Albemarle, NC
« Reply #1 on: February 13, 2011, 12:42:05 PM »
Marc, On an Eagle 10 (and I think an 05) take a look in the electric service panel beside the driver on the outside are a ton of fuses.  They make their contact at the end of the fuse.  They may have been a good idea at one time, but they can give you grief as the spring pressure drops over the years.
Spin each one and I think that at least the dash lights will come on.  I also think the tail lights to through those fuses.
I have a sheet of all of the fuse connections on a 10 and would be happy to work with you to see if they are close to the same for an 05.
Give me a call if you need more help three zero three 478 thiry five zero one.
« Reply #2 on: February 13, 2011, 01:35:42 PM »
Jim, no fuses in the panel all self setting breakers and relays my understanding he has 1 tail light he needs to open the doors on each side and check for power at the junction box on each side and he may have the sealed tail lights and they are bad,the dash and tail lights are on the same circuit.
If he has clearance lights he should have 2 tail lights,that bus does not have the 05 dash so who knows lol you know the converter thing.
« Last Edit: February 13, 2011, 02:06:40 PM by luvrbus » Logged
« Reply #3 on: February 14, 2011, 02:45:07 PM »
Marc,
Do you have marker lights?
I don't know about Eagles but many buses have marker, dash and tail lights on the same circuit.
blue_goose
« Reply #4 on: February 16, 2011, 06:21:57 AM »
On my 05 the tail lights and dash lights are on the came relay and the marker lights or on a different one.
Jack
thejumpsuitman
« Reply #5 on: February 16, 2011, 07:22:32 AM »
I do have marker lights.  Every time I have ever seen dash lights out, tail lights are out as well.  It must be a universal setup.
Actually, one tail light started working.  Still no luck with the others or the right turn signal.
This is a minor concern of course until we are back on the road.  Wink
Albemarle, NC
« Reply #6 on: February 16, 2011, 01:59:16 PM »
If one tail light works you probably have a problem at the rear since they are directly connected. Probably a bad connection at the rear electrical panel, very often just a corroded terminal or wire. Had a bunch of those in my 4104.
Again, I'm assuming Eagles have rear panels.
Turns and brakes are on a different circuit.
I'm eventually going to put my dash lights on a separate circuit, I'm pretty tired of this problem!
Again, older GMs have tail lights, dash  and markers together.
