April 26, 2018, 08:14:36 PM *
Author Topic: water temp sensor  (Read 906 times)
carlb
« on: February 19, 2011, 04:20:42 PM »
I have a 1988 Vogue Diesel on a Crown chassis powered by an 8.2L turbo detroit diesel. I was about 4 miles from home when the water temp alarm and chime came on.  The water temp gauge was normal, about 195.  I pulled over and checked it out but found nothing unusual, no leaks normal temp. I waited an hour till the temp gauge was down to 80, but the alarm did not reset. I drove back home and the temp gauge read normal. Back home I started looking around, found the temp gauge sending unit right in the water pump manafold. My problem is that I cannot find any other water temp sensors. Anyone know where a second sensor might be located?
