May 26, 2018, 10:36:49 AM *
Author Topic: Oil Pump  (Read 4735 times)
« Reply #15 on: March 02, 2011, 06:14:30 AM »
I would say your gauge is off a little Wayne the DD have a relief valve inside the engine that dumps the oil back into the pan set at 50 lbs you can shim it an get another 5 or so lbs but hot you get 5 to 50 lbs of oil pressure so there is nothing wrong with your buds oil pressure
wal1809
« Reply #16 on: March 02, 2011, 06:34:40 AM »
I believe your right Luvrbus.  I do believe his motor would have tanked by now anyway as that pressure has been constant for a year.
www.snakebreaker.com
