May 26, 2018, 10:06:14 PM *
Pages: 1 [2] 3   Go Down
Author Topic: 8V71 Won't Start  (Read 11189 times)
« Reply #15 on: March 08, 2011, 06:57:24 PM »
Boyce,
Thanks, my concern is the smaller size of my auto pump connections, they are much smaller than the supply line on my bus.
Maybe the one you show has larger tubing, do you know the size?
I'm guessing they have simple rubber flapper check valves and should allow the mechanical engine pump to pull fuel right through.
However, it sure takes a lot more fuel to climb a long grade than to idle. I found that out when I had a small air leak at the gasket of my primary fuel filter!!
Greg Smith
GREGOOSE
« Reply #16 on: March 08, 2011, 07:16:11 PM »
Gus
My mechanical pump quit one day. I used an electric pump inline (the type used on automobiles) nothing big and fancy. The bus runs like a dream using just that pump. Maybe this spring I'll fix that mechanical pump.
Greg
Life may not be the party we hoped for, but while we're here, we might as well dance.
« Reply #17 on: March 08, 2011, 07:23:01 PM »
The inline electrical pump is a nice backup.  My last bus had an electric pump right at the fuel tank and it worked fine.  However, I once installed one in an old motorhome I had.  I first put it in series, but it did not pass enough fuel to run the engine.  I therefore switched it to parallel.  I would want to be sure that whatever pump I installed had enough passive flow to let the engine run on the mechanical pump alone.
Greg Smith
GREGOOSE
« Reply #18 on: March 08, 2011, 07:38:35 PM »
Put a pump in line, hook up a toggle switch, turn it on and GO. You have nothing to lose.
Greg
rampeyboy
1954 Scenicruiser PD4501-227
« Reply #19 on: March 09, 2011, 02:39:17 AM »
I too am concerned about the smaller fuel line diameter/flow rate. That is why I pointed out I haven't been on the road with it yet. The lines on the auto pump are 5/16 if memory serves. I had to adapt it to the bus line which I believe is 1/2" I have not been running the electric pump since I got the detroit running. I have been just letting it pull through the electric pump. Seems OK so far.
Boyce
Boyce Rampey
Columbia, SC
Scenicruiser 227
« Reply #20 on: March 09, 2011, 05:31:29 AM »
5/16 works good you guys as my dad said put the thinking hat on fuel is pumped up and goes out a 0.070 hole on the return line I use the rotary type pump not a impulse cheapo has worked good over the years for me
« Last Edit: March 09, 2011, 09:02:30 AM by luvrbus » Logged
« Reply #21 on: March 09, 2011, 08:44:05 AM »
Clifford, I am not sure I understand what you are saying.  .70 inches would be almost 3/4 inch while 5/16 is just more than a quarter.  Do these pumps give their passive flow through rates?
« Reply #22 on: March 09, 2011, 09:05:11 AM »
Check it now Lin 0.375 would have been 3/4 I left off a zero in the first post
« Reply #23 on: March 09, 2011, 09:15:45 AM »
If you say it will work Clifford, I'm sure it will, but .375 is 3/8" which is still larger than 5/16".
« Reply #24 on: March 09, 2011, 09:38:42 AM »
I knew that just wanted to keep you on your toes 0.750 is 3/4 I love you guys looking for mistakes I really do
« Reply #25 on: March 09, 2011, 09:44:26 AM »
Fortunately, we don't have to look very far Cheesy
« Reply #26 on: March 09, 2011, 12:07:57 PM »
Hey Clifford, I am not looking for mistakes.  I am trying to understand what will work.  I am looking to avoid mistakes.
« Reply #27 on: March 09, 2011, 02:48:40 PM »
Lin,
Was your MH pump near the tank?
Greg,
  I really like the idea of the electric pump as a backup to the mechanical pump.
Cliff,
Fortunately I paid attention in school during decimals so you don't keep me on my toes, but you do keep me guessing!!
TedsBUSted
« Reply #28 on: March 09, 2011, 03:27:33 PM »
I'm sort of interested in the flow volume of the mentioned large Auto Zone pump because I always plumb off road equipment with a complicated bypass system and flow-through would make for cleaner and simpler installations.
The crucial data would be knowing the flow volume of the DD fuel pump.
I wonder if the overhaul manual has that spec? I could check sometime.
We know that a 318 can burn a gallon of fuel in three minutes on a hard pull. So the question is how much more flow than .33gpm is needed to assure adequate supply and cooling?
Bus polygamist. Always room for another, especially 04 or 06 are welcome. NE from Chicago, across the pond.
« Reply #29 on: March 09, 2011, 03:49:27 PM »
0.9 gmp fuel spill on a 6v or 8v92 engine Ted fwiw
Pages: 1 [2] 3   Go Up
