April 26, 2018, 08:03:41 PM *
Author Topic: Pesky Acorns  (Read 1741 times)
travlinman
« on: March 19, 2011, 07:01:11 PM »
OK Guys, what is the trick to keep the wheel acorns on? Seems like as they are getting older I loose one every 500 miles or so. I'm sure there is an easy way!
TM
This bus is for sale - https://gm4106.wordpress.com
Hi yo silver
« Reply #1 on: March 19, 2011, 07:04:07 PM »
Mine wouldn't fall off on their own, so I just knocked of a couple on some overhanging shrubs in a turn near the Charlotte Airport. Tongue
Dennis
« Reply #2 on: March 19, 2011, 07:41:22 PM »
A little silicone will do the trick tire guys don't care for it but it works
« Reply #3 on: March 19, 2011, 07:48:37 PM »
give them a little squeeze with a pair of channel locks before you put them on.
« Reply #4 on: March 20, 2011, 09:20:56 PM »
and really he means darn little, like maybe on one hex flat....is PLENTY.
Donald PH
« Reply #5 on: March 24, 2011, 07:24:01 AM »
After putting them back on i take a rubber mallet and give each one a tap or two to make sure they are completely on and seated.  Always find a couple that i thought were all the ways on that still had a little ways to go. Smiley
travlinman
« Reply #6 on: March 27, 2011, 08:06:38 PM »
Thanks Guys,
Hopefully I will be able to keep them on now.
TM
jackhartjr
« Reply #7 on: March 27, 2011, 08:15:59 PM »
The truck stops sell a special little tool that helps take them off.  It is like a cross between a large pair of pliars and a large socket.  It has rubber where the acorn will sit on it while taking them off so as to not scratch them.  You will find it near the acorns.  If you put a little squeeze on them prior to putting them on they will go on tighter.
That only works on the metal ones, not the plastic ones.
Jack
Jack Hart, CDS
8V71 Detroit
4 speed Spicer Trannsmission
