June 22, 2018, 05:41:55 AM *
Author Topic: Air filter  (Read 1827 times)
Le Mirage
Le Mirage XL 1987
« on: September 18, 2006, 01:50:11 PM »
Hi gang! (sorry for my poor english)
This week-end, after you read you,† I have cleaned the air filter on my 8-92. Curiously, I† have discovered the oil in the tub with 1 inch soil(?).
Questions:
What oil you put in? Same oil that in the motor? 15-40? Can I put used oil (after filtered?) in the tub?
And the filter around the casing, do you clean it so? If affirmative, how?
So, I have cleaned the duck in the center of the casing (ouach!). Oil, dust and soil was sticking on the "wall". I think that, there is more time, the cleaning was not to do. I have the bus only since 2 years and I am in processing of converted.
I hope you understand me...sorry
Thanks!
GaŽtan
Canadian French
Quebec, Canada
« Last Edit: September 18, 2006, 01:57:24 PM by Le Mirage » Logged
GaŽtan & Manon (french canadian)
Prevost, Le Mirage XL, 1987
Quebec, Canada
http://latchodromquebec.blogspot.com/2010/05/la-fin-du-voyage.html
prevost82
82 Prevost 8V92ta 6 speed
82 Prevost Marathon XL
« Reply #1 on: September 18, 2006, 02:04:40 PM »
Hi Gaetan ...you should be running 40 weight in your detroil diesel... here's a link
http://www.detroitdiesel.com/Public/brochures/7SE270.pdf
You could run the same motor oil that you use in your car 10-30 in your air filter
Ron
PS  Are you the guy that fabricated and install 2 slide-out in your Prevost?
Le Mirage
Le Mirage XL 1987
« Reply #2 on: September 18, 2006, 04:14:15 PM »
PS† Are you the guy that fabricated and install 2 slide-out in your Prevost?
Hi Ron!
No, I'm not...but I think seriously to install a slide in the front. Miracoach install the slide. I want to do evaluate the cost for.
http://www.miracarcoach.com/eng/miracarcoach.php
Thanks for the link Ron
« Last Edit: September 18, 2006, 04:18:42 PM by Le Mirage » Logged
Quebec, Canada
