May 23, 2018, 11:19:05 PM *
Author Topic: Jake Brake Wiring Diagram  (Read 3986 times)
travlinman
« on: April 16, 2011, 07:48:27 PM »
Hey All,
I need a wiring diagram for my jake, during the dash redo a few wires were forgotten about. Here are the particulars,
1962 4106
8v71 w 730
Two stage jake w/high idle buffer switch
Also, were do I look for the high idle buffer switch on the Engine?
TM
This bus is for sale - https://gm4106.wordpress.com
« Reply #1 on: April 16, 2011, 08:06:00 PM »
Easy one to read TM is www.bernhardbus.com the fast idle if you have one will be below the controls screwed into the governor housing with a 1/4 inch air line come from the holding cylinder on top of the governor controls and will have 2 wires only 2 wires you have no fast idle.
Be real careful if you have never worked on Jakes the buffer switch if not adjusted right the engine will run away and the only way to stop it will be cut the fuel off
« Last Edit: April 16, 2011, 08:25:13 PM by luvrbus » Logged
travlinman
« Reply #2 on: April 16, 2011, 08:47:43 PM »
Thanks!
« Reply #3 on: April 18, 2011, 08:21:42 AM »
I simplified my Jake installation and eliminated the fast idle option.  Why-because I already have a King Cruise control that can be used as a fast idle-so why have both?  Makes the governor just a bit simpler.  Good Luck, TomC
« Reply #4 on: April 18, 2011, 08:28:07 AM »
Plus you can purchase the King Cruise for less than you can buy the fast idle buffer switch
from DD 150 bucks cheaper
tomhamrick
« Reply #5 on: April 19, 2011, 04:44:34 AM »
How much is the King Cruise?
Tom Hamrick
1991 Prevost H3-40 VIP
1981 Eagle 10
Forest City, NC
« Reply #6 on: April 19, 2011, 06:15:18 AM »
I buy for around 500 bucks Tom list price is 695.00 shop and some times you see it below 500.00 best cruise control for a mechanical engines out there
tomhamrick
« Reply #7 on: April 19, 2011, 12:24:46 PM »
Thanks Clifford.
Tom Hamrick
1981 Eagle 10
Forest City, NC
