April 26, 2018, 11:37:06 PM *
Author Topic: Welder plug works!!  (Read 1729 times)
happycamperbrat
« on: April 17, 2011, 05:47:32 PM »
I got the plug in and tested it, photos are here http://s495.photobucket.com/albums/rr315/happycamperbrat/Little%20GTO/home%20hookups/ with captions about the job. But now Im back onto the RV plug and it is only 3 wire sooooooo do I need a single pole breaker now or if not, what the heck do I do with the other hot wire off the double pole breaker?
Stormcloud
FMCA#407220
« Reply #1 on: April 17, 2011, 06:19:00 PM »
You need a single pole breaker. 30amp would be standard with #10 wire for connection.
Mark Morgan
1972 MCI-7 'Papabus'
8v71N MT654 Automatic
happycamperbrat
« Reply #2 on: April 17, 2011, 08:49:46 PM »
Thank you Storm! I just had a light bulb go off in my head about all of this. Yes, I do have to use a single pole to run 3 wired anything BECAUSE otherwise if I split the double pole to run different things then I would again run into the same problem as i did originally with drawing 30 amps out of an instument (like the 120 outlet) and having it catch fire........ right?! It's what everyone was trying to tell me!
« Last Edit: April 17, 2011, 08:51:52 PM by happycamperbrat » Logged
« Reply #3 on: April 17, 2011, 09:16:31 PM »
Teresa,
Now you have me confused.  All the installation photos are of a 14-30R, which is a 4-wire circuit requiring a double-pole breaker.  The last photo, of a retail box, shows a TT-30R, which is a 3-wire outlet.
Are you going to replace the 14-30R with the TT-30R?  I thought you were just going to use an adapter from the 14-30 to a TT-30?
If you are going to replace the 14-30 with the TT-30, ideally you would change to a single-pole, 30-amp breaker.  The second (red) hot wire would be removed.  However, it is not unsafe to continue to use the double-pole breaker in place now.  Just leave the second pole unconnected.
happycamperbrat
« Reply #4 on: April 17, 2011, 09:22:07 PM »
Sorry Sean. I am leaving the 50amp as is. Just today I finished the installation of the 4 wire 30amp welder outlet. But Im still going to install a 3 wire 30amp RV plug, which is the last photo. I decided not to use the adapter after all, and am just going with a rv dedicated 30amp outlet.
« Last Edit: April 17, 2011, 09:25:09 PM by happycamperbrat » Logged
« Reply #5 on: April 17, 2011, 09:59:54 PM »
Ah.  OK, then, yes, you want to use a 30-amp single pole breaker and #10 THHN or THWN wire.
happycamperbrat
« Reply #6 on: April 17, 2011, 10:05:25 PM »
Gottcha! And I know you and your lady travel thru Death Valley area now and then, come on by and hook-up  Grin
