May 23, 2018, 08:07:13 AM *
Author Topic: Sheppard Steering Line Routing - 4106  (Read 1743 times)
travlinman
« on: April 30, 2011, 08:50:33 PM »
Hey Guys,
Just finished replacing the oil in my Sheppard Power Steering, and it still howls. Not as bad but still not right. The correct  air bleeding procedure was followed with no better results. So now on to the next idea - are the supply return lines hooked up correctly? Check out the photos fellow 4106ers and let me know! See this thread as to what has already been discussed. http://www.busconversions.com/bbs/index.php?topic=19090.0
TM
This bus is for sale - https://gm4106.wordpress.com
travlinman
« Reply #1 on: April 30, 2011, 08:51:55 PM »
One More!
06 Bill
« Reply #2 on: May 01, 2011, 03:12:29 AM »
TM   Try taking the filter out of the reserve ( fill ) canister as a trial run. If it in fact has one, could be restricting
pump suction (feed). leading to growl just like air noise in system.      06 Bill
bs4104
« Reply #3 on: May 01, 2011, 12:29:19 PM »
You might try a increasing the size of the line from bottom reservoir to the pump this is a low pressure side. Also what weight oil are you using?
102A3 N14 Auto Shift
travlinman
« Reply #4 on: May 03, 2011, 08:25:30 PM »
I've got 15w40 in the system now.
So, is the filter the item in the upper left of the second photo??
TM
Utahclaimjumper
« Reply #5 on: May 04, 2011, 05:57:33 AM »
Straight 10 weight works best.>>>D
Utclmjmpr
 EX 4106 (presently SOB)
Cedar City, Ut.
 72 VW Baja towed
« Reply #6 on: May 04, 2011, 06:26:47 AM »
Upper left is the pressure side filter, which you may be able to disassemble and clean.  The other filter is inside the bottom of the reservoir, upper right of that picture.  That is the filter mentioned as a possible restriction on the input (suction) side of the pump.
« Reply #7 on: May 04, 2011, 06:45:08 AM »
Here is a link to one of the better power steering sites  www.steeringcomp.com/TSTT.htm
