June 18, 2018, 12:47:16 PM *
Author Topic: heater core  (Read 2170 times)
berrybus
« on: September 23, 2006, 02:26:35 PM »
i removed heater core from bay compartment. whats best to do with the inlet and outlet ? if i plug them off whats best to use? also if i leave valves closed in back motor compartment do i lose heat in core in dash?
"No man is a bus."
« Reply #1 on: September 23, 2006, 03:05:57 PM »
If you have a GMC, you'll loose all coolant flow to the front if you shut off the valves in the engine compartment.
The Same if you have a Flx or an older ACF-Brill.
Those are the only ones I know about from first hand experience.
I hope this Helps!
berrybus
« Reply #2 on: September 23, 2006, 03:56:14 PM »
i forgot to mention its a mci 9. thanks jim
"No man is a bus."
« Reply #3 on: September 23, 2006, 08:30:37 PM »
I can't say what's best to use to plug them, as I didn't remove mine. If it's copper, you could probably solder caps on the lines. Or, you might could tie the two ends together with heater hose.
I do know, though, that if you shut off the valves in the engine compartment, you will lose coolant flow to the driver heat/defrogger.
craig
« Reply #4 on: September 24, 2006, 04:46:01 AM »
     When we removed the heater core from our MC-8, I wanted the option of re-installing it later, if I changed my mind.  I blocked the lines to the heater core using a short length of rubber heater hose with an appropriate sized pipie nipple and cap in the other end of the hose. Hose clamps finished the process.  Hope this helps, Jack
