June 18, 2018, 08:52:21 AM *
Author Topic: I need a better deal on Detroit parts  (Read 2168 times)
Zeroclearance
« on: May 10, 2011, 10:55:20 AM »
Prices have gone thru the roof lately.   My Detroit dealer is not budging on a previous quote.
I'm looking for a factory Aux Accessory Drive  part number R23518333.   Last year I was quoted $299.00  now it's $421.00   I guess I could always rebuild the unit,  but I'd have to make the tooling required to tear it apart..
I'm also looking for a Engine mount support  part number 23511743
Any advice or help would be great.
« Reply #1 on: May 10, 2011, 11:28:05 AM »
Check,the number RR2354000 that is a DD rebuild number but they are 400 bucks plus nothing cheap on a DD now that is a pretty hefty drive what are running requiring that drive on a 60 series, is the other number a brace
« Last Edit: May 10, 2011, 12:01:46 PM by luvrbus » Logged
Zeroclearance
« Reply #2 on: May 10, 2011, 12:14:18 PM »
Clifford, I'm running a 450amp Niehoff alternator.  The rebuild cost has went up $100 in one year.   I can understand if the parts were imported from Germany or if they were rebuilt in Germany.
Don Fairchild
« Reply #3 on: May 10, 2011, 04:19:37 PM »
Hey Zero double check the part numbers for me. I had my ddc guy look up those #'s and he could not find them. Give me a engine model serial # and I will see what I can do for you.
Don
« Reply #4 on: May 10, 2011, 05:08:22 PM »
Don, use the RR2354000 number the 23518333 is a obsolete number with the 23511743 all I find is a brace
Zeroclearance
« Reply #5 on: May 10, 2011, 06:56:56 PM »
Don,  I am uprating the engine specs to get the cradle 50DN setup.   The specs that I have are>> Serial number 06R0221694  with a model number 6087GK28
Clifford is correct,  I need the bracket that mounts on the side of the engine to support the 50DN craddle.  I also need the brace > 23511743.
Don Fairchild
« Reply #6 on: May 17, 2011, 10:05:17 AM »
Zero, I found the 23511743. I have to order it but can have it in a couple of weeks.
 The other one need to come from the bus co.
Hope this helps
Don
