February 23, 2018, 04:55:37 AM *
Author Topic: Generator  (Read 4196 times)
« Reply #15 on: June 08, 2011, 04:07:29 PM »
I have a liquid cooled Honda 6500 that is a propane unit. I can't argue with those that have diesel powered units because they are probably your best option. I would however hold out and lean the propane and liquid cooled way if you decide to go in that direction. Just another 2 cents in the till.....
« Reply #16 on: June 08, 2011, 04:12:35 PM »
I Have it plumbed through removable 1"3/4 pointing down in the engine compartment for now, like I mentioned earlier it is only temporary. At one time I had mind to build a box for it, but it would only be a waste of materials for a gas jobby, besides the last thing I wanted was gas in an enclosed area. Let me say that mine is not the ideal way to go if you have a budget that allows the purchase of a suitable diesel or propane genny that would be the route I would take, me I am just getting by with mine till it's time belly up to the bar Wink best of luck. Smiley
  Edit. just for the record, so long as you are mindful of the equipment's limitations and how much you ask it to do it should work fine. when we go on a trip it is basically pole to pole for elec, I power up what I need in the bus while working on it during the day.
« Last Edit: June 08, 2011, 04:21:40 PM by van » Logged
chev49
« Reply #17 on: June 10, 2011, 05:19:59 AM »
Speaking of diesel gensets... i think there is one in portland ore craigslist for $1000. posted recently.
