May 26, 2018, 03:13:37 AM *
Author Topic: Real Time Help Needed - Air Brake Leak - 4106 W Spring Brakes  (Read 5752 times)
« Reply #15 on: June 26, 2011, 09:09:22 PM »
I thought Scotch was an alcoholic drink!
Grin  BK  Grin
« Reply #16 on: June 26, 2011, 10:04:12 PM »
 This is what I use to control my spring brakes.
http://www.anythingtruck.com/Merchant2/merchant.mv?Screen=PROD&Category_Code=HTP-AIRB&Product_Code=060-065104
Read up on shuttle valves a bit, still don't get how they can function as a relay ...but the R12 works great to control spring brakes.
Glad to hear you are off the road....don't spend too much $ on air lines....they are usually surprisingly inexpensive.
Make sure you block the suspension as well as scotching the wheels.  Air suspended buses drop hard and fast....in case you haven't been told that a million times already.
uncle ned
« Reply #17 on: June 27, 2011, 06:53:46 AM »
Ken  It is hard to talk to these people from north of the Masson Dixon line. Most of them talk faster than I can hear.
Also remember the War of Northern aggression,
I am afraid we will finally lose it because they are moving down here so fast that we are just about out numbered.
so just scotch it up.
uncle Ned
all in good humor
4104's forever
6v92 v730
Huggy Bear
babell2
Brice
« Reply #18 on: June 27, 2011, 09:14:43 AM »
Quote from: travlinman link=topic=20539.msg224617#msg224617 date=130914350
Anything else I should be thinking about while I am under the beast?
TM
[/quote
YES!  If you are working UNDER the bus. Block the body up! Don't get crushed! That would ruin many peoples day.
Good luck on the repair.
Brice
The other Brice
NEWELL in South Carolina
« Reply #19 on: June 27, 2011, 05:13:13 PM »
From bendix:
http://www.bendixvrc.com/itemDisplay.asp?documentID=5772
Should answer some of your questions . . . . & a few you didn't even know to ask.  Grin
« Reply #20 on: June 28, 2011, 05:13:52 AM »
I'm guessing that your 4106 was not born with spring brakes, so whatever you find under there was added by someone of unknown expertise.  It would behoove you to study the Bendix manual and know for yourself exactly what you have.
travlinman
« Reply #21 on: June 29, 2011, 06:55:29 AM »
Hey Guys - Once again thanks for all the advice it is much appreciated. Here is an update:
I was able to locate a Bendix QR-1 quick release valve, the closest replacement for what was in there. I installed the new valve, DOT fitting and air lines on Monday afternoon. All extra fittings have been removed from the system with just air lines running to the brake cans from the valve. Our spring brake system works much more smoothly now, I can now see how slow it was to apply.
The rest of the drive down to San Francisco went well with the exception of the crazy rain storm yesterday!!
TM
This bus is for sale - https://gm4106.wordpress.com
« Reply #22 on: June 29, 2011, 10:19:34 AM »
Woo hoo! Way to get'er done.
