June 17, 2013, 10:59:37 PM *
Pages: 1 2 [3] 4   Go Down
Author Topic: Wow Fired first mini-split  (Read 3673 times)
Nick Badame Refrig. Co.
« Reply #30 on: July 11, 2011, 06:05:17 PM »
Hi Guy's,
Most ductless split mfg's won't recommend mobile installations for 2 reasons.
1) as stated above, the copper lines and connections are not designed to resist the stress of movement.
2) The evaporators are built with very shallow condensate pans which could spill and damage furniture and walls.
This doesn't mean that you can't.... Just don't ever tell them what you installed it in! Lol
Also to answer the DC compressor question, the inverter boards within the units are very elabrate. They control
a very wide range of compressor speeds as well as fan speeds to optomize efficency. It would be very hard to mimmic
this range with straight DC current within your coach.
This year has been a record breaker for us with Ductless Split installs! 98% of them in homes and and 2 so far in an
Ice Cream truck.. Next Monday we start a quad Sanyo install for a home owner in Cape May.  A 9,000 btu and 3- 7,000 btu's.
utilizing one 30,000 btu quad condencer. Each zone is self controlable and all the evaporators have UV air cleaners within.
So far this year all the Sanyo's we installed were 19 SEER+ too.
Bobby, Glad to hear your happy with your Ductless Split!
Good Luck
LarryN 4106
« Reply #31 on: July 11, 2011, 07:34:02 PM »
Larry, can you clarify what "takes itself off-line" means?  5 minute wait to auto reset, hard reset by a technician, buy  a new control board...
thanks, Brian
sorry, been travelin'
I believe the last of these mini's we specified were Carrier. They went into a auto reset that was more like 45 minute. I will have to go into the manual. My point was that these do like a steady voltage with no surges. In the instance I mentioned, city power, then generator power, then city power again, then city power again. All with a large commercial genset (250 KW) but in the middle of an ice storm. Everything was automatic.
« Reply #32 on: July 11, 2011, 07:47:38 PM »
Holy S*** I open one of the Sanyo's  man the electronics on those are out of this world why would anyone even consider installing one in a bus, are all the inverter type made that way it blew me away all the circuitry on it I'll pass I don't care how much cool air they make that looks like a fortune to have one fixed
Melbo
MC8 under construction
« Reply #33 on: July 11, 2011, 08:08:56 PM »
You don't fix them you replace them
Kind of like the light bulb in your tail light
They really are pretty cheap and when properly installed they pretty much don't need any thing to keep running
We are after all a disposable society
HTH
Melbo
« Reply #34 on: July 12, 2011, 05:03:55 AM »
last report. Hottest day of year yesterday. weather man said was and hopefully will be one or twice a year occurrence.  Got up to 76 in coach with one unit (9000 ); 0n kicked 2ND on and minutes later down to 70.  parked in steel building no ac or heat for that matter ; building in the sun. 97 degrees and humidity in 80's.Heat index 117      Time will tell on durability..   I still like mags and spark plugs or basic diesel non electronic  but that's not here anymore. so let's go for the ride with new technology: probably disposable.  Bob
« Last Edit: July 12, 2011, 05:28:50 AM by robertglines1 » Logged
Pete359EX
86 Prevost XL
any excuse to buy new tools
« Reply #35 on: July 12, 2011, 02:15:13 PM »
Great job Bob!! Sounds like this will be in my future.
Fred
Fred, 1986 Prevost XL, just beginning...Plans for roof raise, slide-outs, extension to 45', and maybe repower to CAT.
Kenny
« Reply #36 on: July 12, 2011, 04:12:00 PM »
Still see no pictures from anyone on their installations. What's up with that?
buddydawg
« Reply #37 on: July 12, 2011, 04:51:20 PM »
I'll go first.  I was digging to see if I had some good pics.  I'll post a few tonight as I find them.  I will also make an effort to get some better shots for your critique.  This one is a Sanyo 12K BTU mounted over the table which is built over the wheel well.  It is not in the way at all and has been in operation for 3 years.
« Last Edit: July 12, 2011, 05:15:42 PM by buddydawg » Logged
1972 GMC T6H-5308A #024
« Reply #38 on: July 12, 2011, 05:01:21 PM »
I would be quite interested in seeing pictures of where folks have installed the condenser units to get proper airflow.
buddydawg
« Reply #39 on: July 12, 2011, 05:04:47 PM »
Another of the chase for the lines
buddydawg
« Reply #40 on: July 12, 2011, 05:13:18 PM »
The outdoor unit for the Sanyo  is located behind the grille in the lower right of the pic.
buddydawg
« Reply #41 on: July 12, 2011, 05:18:11 PM »
Outdoor unit for the rear mini-split.  It is covered in the pic since I was painting.
« Reply #42 on: July 12, 2011, 07:12:30 PM »
Darrel found some evaporators you can conceal for the Sanyo's has anyone here used those ? he is not going with the evaporator that go on the wall for some reason and the ceiling units take up to much room on the top
Jackling54
1954' crown supercoach
« Reply #43 on: July 13, 2011, 05:22:59 AM »
Well I'm a week away from Pre installing my condensation and refrigeration lines,and I'm using high pressure hose not copper.What have u technologically  advanced users use ? Cool
"I'd rather people hate me for who I am than love me for who I am not" - Kurt Cobain
« Reply #44 on: July 13, 2011, 09:41:14 AM »
Bob from the back woods; soft ref grade copper with attention paid to any place it might rub through insulation with a little extra rubber padding to prevent damage to copper. Anchor well to prevent movement;spray foam tight inaccessible areas. Just my way.  Bob
Pages: 1 2 [3] 4   Go Up
